Originally Posted by jvijay86
....in Device 1, i changed it to DMA but the current transfer mode shows PIO mode.....
Your Device 1 is the DVD Writer. The transfer mode=PIO is the colpritt.
If there is a checkbox 'Let BIOS determine transfer mode' tick it. Take a restart.
If the above step doesn't solve the problem (i.e. after restart the transfer mode is still =PIO) then:
You need to attach the DVD drive to the secondary channel. (You will need another IDE cable; 80 Conductor cables are preferaable rather than 40 conductor one.)
If still not solved give your Motherboard & DVD-RW model numbers here.
