Old 05-08-2004, 12:08 PM   #1 (permalink)
Posts: n/a
Default Bios or ????
I have a Delta motherboard (model no:M694X-MX) with VIA chipset running W2k. Recently, i have replaced my lithium CR2032 battery as system clock wasn`t functioning well.
& also sometimes it doesnt detect CDROM & CDR.
& my machine doesn`t power off automatically even though it has an ATX power supply. By default it should turn off automatically.
Now i have 2 start my PC without lithium CR2032 battery bt with it, it doesnt start.
Plz plz plz help me out.
Old 05-08-2004, 05:07 PM   #2 (permalink)
Posts: n/a
koi techi nahi hai kya ????
Old 05-08-2004, 07:02 PM   #3 (permalink)
tell us a lil more abt ur problem
and what do u mean power off automatically /
why would it power off automatically ??
and what did u say ? it starts with the battery or no?
No Mercy, No Limits.
theraven is offline
Old 05-08-2004, 07:12 PM   #4 (permalink)
JAK
What the Heck !
JAK's Avatar
Default Re: Bios or ????
Originally Posted by amp
& also sometimes it doesnt detect CDROM & CDR. .
U did not specify wher they are not gettin detected...in windoz or in BIOS
Does ur CDROM/burner light blink during boot...???
Anyway check ur IDE cables n their connections, also check the power supply....
Install ur mother board drivers
Didnt quite get the hang of ur question..Elaborate please...
Risk more than what others think is safe.
Care more than what others think is caring.
Think more than what others think is thoughtful.
Do more than what others think is possible.
JAK is offline
Old 06-08-2004, 04:04 AM   #5 (permalink)
Posts: n/a
No problem with that.You clearly check the jumper setting of CD-ROM/RW.I also faced same prob., with old COMPAQ AMD K6 330MHz machine.
>Connect the cd drive as a master in PRI or SEC IDE then it will detected next boot
>Even wrong connections in a MB cause sutdowning prob., or may be it is a wonder of WINDOSE
>U replace a CMOS battery with new Lithium-Ion Battery it solves this one
Old 06-08-2004, 12:06 PM   #6 (permalink)
Posts: n/a
power off automatically / //
means : if i shut down windows, my cpu light is on & monitor display is also on with white or grey bg.
cdrom & cdr not detected : in bios as well as in windows.
starting my PC without lithium CR2032 battery bt with it, it doesnt start. //
means : bios ko tang diya.
Old 06-08-2004, 12:10 PM   #7 (permalink)
Posts: n/a
battery remove kiya hai ... @ this time ... my both optical drives get detected ...
Old 07-08-2004, 08:25 AM   #8 (permalink)
aadipa's Avatar
install motherboard and graphics drivers to get automatic power off.
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 11-08-2004, 11:22 AM   #9 (permalink)
Posts: n/a
Hey, tried installing both motherboard & graphic card drvers, bt no change
& Will my motherboard b in danger, if i work on my PC with the lithium battery removed ????
Old 11-08-2004, 11:23 AM   #10 (permalink)
Posts: n/a
Old 13-08-2004, 10:48 PM   #11 (permalink)
Seems like a unique problem!!!
Do u mean to tell that PC without battery detects Optical drives & with the battery, it is not able to detect the optical drives????
sUlPhUr|nE` is offline
Old 13-08-2004, 11:47 PM   #12 (permalink)
take your computer to a TANTRIC, maybe he can help u ha ha
She moves like she dont care...smooth as silk cool as air..!
superwiz is offline
Old 14-08-2004, 09:34 AM   #13 (permalink)
Ashis's Avatar
Default Don't take pain any more !
Brother, Take my Advise (Simple & Best)
Upgrade UR MotherBoard
I understand it costs but its worth it.
(I am serious)
Ashis is offline
Old 14-08-2004, 02:54 PM   #14 (permalink)
Booting Nicotine!!
spironox's Avatar
sounds like ur MB got a major rehaul to be done ..contact service center soon .....
http://spironox.blogspot.com
Rig : Asus P4 p 800SE ( happy )
Netbook : Google chrome Cr-48 Mario !!! now that's what i call lucky & also an iBookG4 (2004)
spironox is offline
Old 14-08-2004, 05:31 PM   #15 (permalink)
EinSTeiN's Avatar
Ya upgrade ur mobo. The contacts may have rusted.
;) ~~EiNsTeIn~~ ;)
http://www.tejuspratap.co.cc
EinSTeiN is offline
