Old 26-12-2004, 02:50 PM   #1 (permalink)
Default autorun
i am creating a cd in which i want to autorun a file in HTML FORMAT. HELP ME
krishnansurya is offline
Old 26-12-2004, 11:10 PM   #2 (permalink)
CCIE# 20863
Hey, didn't u ever use digit CDs? They all have HTML based interface and they autorun. Digit uses a program begin.exe to launch internet explorer, which opens the Agreement page. When U click on I AGREE button, it just opens a fullscreen window having the interface page.
I don't know whether u can use begin.exe for free or not, but u can try it in ur CD, copy autorun.inf and begin.exe to root of ur cd and change the paths of main html page in autorun.inf, and it will autorun.
Digit Guys, I don't know if using ur begin.exe is legal or not. If it is not, I would suggest krishnansurya to not to use the file.
Bugs can neither be created nor be removed from software by a developer. They can only be converted from one form to another. The total number of bugs in the software always remain constant.
theKonqueror is offline
Old 27-12-2004, 12:50 PM   #3 (permalink)
h4ck3r
Posts: n/a
@ the konqueror : pls be sure to guide a person rightly
So u want autorun..ok to create a autorun.ini is this simple...
The autorun.ini or sometimes inf file is responsible for the cd to autorun.The file should be as follows
[autorun]
open=index.htm ; or te name of the .htm file
icon=name.ico
Make sure you write these lines in a notepad and then save it with extension ".ini".. One more condition is tht u should have the index.htm and name.ico (in this case) in the cd or if u have it inside a folder mention the ful path(use copy/paste) and finally put this file inside your cd..
If it is a game cd use setup.exe intead of index.htm and hl.ico if it is half life icon.... Thats it !! its simple 8)
If u wanna know more pm me
Old 27-12-2004, 09:22 PM   #4 (permalink)
or .inf? i make mine with that extension.
anyways as h4ck3r said just open a text doc and paste this in it:
dont paste the text in quotes("")!
[autorun]
open=index.html ("name of your file")
icon=myicon.ico ("in case you have an icon file to replace the drive icon")
label=NAME(" replace the drive name with this name")
save as
Autorun.inf
the icon file and the html file should rest in the same directory as the inf file
lamrinnirmal is offline
Old 29-12-2004, 11:11 AM   #5 (permalink)
ya create simple autorun .inf is tru
sheladiya chetan
chetan is offline
Old 29-12-2004, 11:26 AM   #6 (permalink)
Laptoping
Sourabh's Avatar
huh?? i m not sure whether this
open=index.htm
really works or not :roll:
i tried it once and it doesnt work
i suppose only open=somefile.exe only works
someone plz clarify
Sourabh is offline
Old 29-12-2004, 12:09 PM   #7 (permalink)
tuxfan's Avatar
My experince was same as that of Sourabh. I think only exe files can be run. Just think. Digit (and all other mags) keeps a .exe file that runs a .htm file. If it is possible to run a .htm file directly, why would they keep a .exe file?
tuxfan is offline
Old 01-01-2005, 12:30 AM   #8 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
guys, u can do it without begin.exe also...
Create an autorun.inf in notepad...
ADD :
[autorun]
icon=<someiconname>.ico
open=begin.exe iexplore&-k CDREPLACE<somehtmlfilename>.htm
And hey.... replace <someiconname> with whatever name u please &
<somehtmlfilename> with ur html file name...
i.e replace
<someiconname>.ico
with
icon.ico
(for eg.)
with
index.htm
(for eg.)
PS:
For running non-html files like exe files just type open=<somename>.exe
koolbluez is offline
Old 01-01-2005, 12:43 AM   #9 (permalink)
h4ck3r
Posts: n/a
open=index.htm
someone plz clarify
I am damn sure tht open=index.htm works as long as the index.htm file is in the same folder in which the .ini file resides.
Old 01-01-2005, 01:04 AM   #10 (permalink)
Laptoping
Sourabh's Avatar
@ h4ck3r:
well i just posted in wht i observed
i have myself experienced it so have shared it in here and also stated i m not sure abt it and mebbe i cod have been wrong
but someone else too has had a similar experience, so my observation is hopefully correct
well the htm file mebbe wodnt have been working coz i tried it on IE 5.0 i suppose on win2k mebbe thts the reason
ill check it again the next time i burn a data cd
Sourabh is offline
Old 06-01-2005, 12:47 PM   #11 (permalink)
h4ck3r
Posts: n/a
Default Iam not fighting
@Sourabh
Iam not fighting..thts not what we are here for...
Try ie6 or firefox and it will work..iam very sure becoz this is the method i employ for every autorun in data cds i create..(game cds also)
Old 07-01-2005, 11:33 AM   #12 (permalink)
tuxfan's Avatar
This is what I said earlier. Any answers?
tuxfan is offline
Old 07-01-2005, 06:23 PM   #13 (permalink)
ramprasad's Avatar
Hi all
Sorry tuxfan..... I have used the autorun.ini file with open="some.htm" and it worked perfectly.... So it is not mandatory to have only application. However only constraint is that the file type type given should be registered i.e. the computer should have an assocuiated application installed...
Regards,
Ramprasad
ramprasad is offline
Old 08-01-2005, 01:50 PM   #14 (permalink)
tuxfan's Avatar
Thats strange. I have tried using a .htm file earlier as autorun and it hasn't worked Has it got anything to do with the OS? I tried it on Win98SE.
tuxfan is offline
- by Krow
