Old 26-12-2004, 11:38 AM   #1 (permalink)
mohanty1942's Avatar
Default Garbage in webpage
In Win98 very often I get a page full of garbages (Screenshot below) while browsing certain webpages.
On clicking 'refresh' I get back the correct screen.
What is the reason ? How to correct ?
No Terms : Just One Condition
mohanty1942 is offline
Old 26-12-2004, 09:16 PM   #2 (permalink)
CCIE# 20863
It looks like u r still using IE 5.0. Installing IE 5.5 or IE 6 will surely help. If it does not help, totally remove IE using tools like IEradicator, then install IE 6 again. It will surely fix the problem.
Bugs can neither be created nor be removed from software by a developer. They can only be converted from one form to another. The total number of bugs in the software always remain constant.
theKonqueror is offline
Old 26-12-2004, 09:17 PM   #3 (permalink)
CCIE# 20863
It looks like u r still using IE 5.0. You may have corrupted MSHTML.dll. Installing IE 5.5 or IE 6 will surely help. If it does not help, totally remove IE using tools like IEradicator, then install IE 6 again. It will surely fix the problem.
Old 27-12-2004, 01:05 PM   #4 (permalink)
h4ck3r
Posts: n/a
Default hey just stick on to firefox
firefox - a way cool browser than ie 6 in many ways..or try lynx if yo using linux ..its also a kewl one
Old 27-12-2004, 03:48 PM   #5 (permalink)
vysakh's Avatar
OPERA is the best
Incompatible message format
vysakh is offline
Old 27-12-2004, 07:36 PM   #6 (permalink)
Thank you 'theKonqueror'. Correct Guess. I have IE 5.0.
Now it is corrected.
- by Krow
