Old 04-11-2006, 04:30 PM   #1 (permalink)
linardni's Avatar
Default Disable add/remove program
Is there any way Add/Remove Program may be disabled so that anyone may not add/remove any program?
linardni is offline
Old 04-11-2006, 04:51 PM   #2 (permalink)
kl_ravi's Avatar
Default Re: Disable add/remove program
By Disabling Add/Remove program applet from control panel, you cannot prevent user from adding programs or for that matter removing programs.
Get TweakUI & just uncheck Add/remove Programs in the control panel tab. Users still can access it by typing appwiz.cpl in the Run Dialog box
Best way is to set a group policy (By typing START> RUN> GPEDIT.MSC) for this...
PS:- Since I am in a hurry please wait for others to elaborate on this method !!!
Everything that follows is a result of what you see here...!!!
kl_ravi is offline
Old 04-11-2006, 04:57 PM   #3 (permalink)
An Esoteric Geek
sridatta's Avatar
To disable Add/Remove Programs,
Open gpedit.msc from Start->Run
Navigate to User Configuration -> Administrative Templates -> Control Panel -> Add or Remove Programs
Enable the property Remove Add or Remove Programs
sridatta is offline
Old 04-11-2006, 05:06 PM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
In "gpedit.msc" goto:
In right-side pane, u can change the options acc. to ur requirements
[EDIT]
sridatta has also posted the same solution while I was typing it
[/EDIT]
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 04-11-2006, 05:32 PM   #5 (permalink)
An Esoteric Geek
sridatta's Avatar
Hey its all bcoz of uuu... vishal
I m learning lots of registry tweaks only from ur posts
sridatta is offline
Old 04-11-2006, 05:54 PM   #6 (permalink)
Microsoft MVP
thnx buddy!
Old 06-11-2006, 03:43 PM   #7 (permalink)
linardni's Avatar
thanx friends...for all ur support
linardni is offline
- by Krow
