Old 03-11-2006, 01:43 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Floppy disk image ! ! !
i have win 98 bootdisk, is it possible 2 create image file of THAT floppy ?
if the floppy fails, i can create another floppy/cd from this image .........
ax3 is offline
Old 03-11-2006, 02:12 PM   #2 (permalink)
Default Re: Floppy disk image ! ! !
Ya, If you have red hat linux CDs, one of the disc contains a file rawwrite.exe It can be used to create image from a floppy.
Plz correct me if I am wrong.
enjoy is offline
Old 03-11-2006, 02:17 PM   #3 (permalink)
Livin' in the ghetto
AshishSharma's Avatar
If I remember correctly when you right click on the floppy drive there was an option to create copy of the disk and then you can always write it to a floppy. Sorry haven used Floppy for ages
~.~ Never argue with idiots, they just drag you down to their level then beat you with experience. ~.~
AshishSharma is offline
Old 03-11-2006, 02:28 PM   #4 (permalink)
Come get Some
DukeNukem's Avatar
coping floppy didnt make a bootable backup
you can use winimage or ultra iso to create floppy's bootable image. then use this image for any > floppy/cd/dvd
or you can make a bootable floppy from windows 98 itself using two ways
either making floopy bootable by using this command at command prompt
"format a: /s" and then copying the need files to it i.e cd drivers and small utilities
or
by using Create bootable floopy from "Add Remove program" which is in control panel. didnt know the name correctly but u'll find it there try switching tabs once there (you need win98 cd or its dump for this step)
Computers are like Air Conditoners, thet stop working properly when u open WINDOWS.
DukeNukem is offline
Old 03-11-2006, 02:58 PM   #5 (permalink)
kl_ravi's Avatar
Best thing is to visit http://www.bootdisk.com/ and download the required bootdisk for your operating system (There are wide range of choices available there).
Now simply insert a floppy and double click on the downloaded EXe file and you're done !!!
Just in case you "toast" your floppy!!! you can try HD-COPY or T-Format
Everything that follows is a result of what you see here...!!!
kl_ravi is offline
Old 03-11-2006, 05:42 PM   #6 (permalink)
ax3
ax3's Avatar
bt ultraiso is just cd\dvd image maker ........ & not floppy disk
found 1 :
Floppy Image v1.5.2 --- freeware
http://woundedmoon.org/win32/floppyimage152.zip
__________
& how 2 create CD/DVD bootable disk from floppy drive ?
ax3 is offline
Old 03-11-2006, 06:41 PM   #7 (permalink)
@DukeNukem copying floppy by right clickin the Floppy drive copies the formatting as well so the result will be a Bootable floppy as well ....
@aX3 you can use Nero to create bootable CD/DVD but obviously not from Floppy Disk ...
Old 04-11-2006, 01:28 PM   #8 (permalink)
ax3
ax3's Avatar
hey ashish ..... i dont think so just by coying flo;ppy make a duplicate bootable floopy ........
i have tried it ..... doesnt work .......
ax3 is offline
Old 06-11-2006, 09:42 PM   #9 (permalink)
Hey Dude .. there is a diff in copying from the floppy and copying the floppy I was referring to something I remember from long back my 98 days ...
Check this : http://www.helpwithpcs.com/tipsandtr...sk_windows.htm
However you can always visit the following link and download the desired file for creating a bootable floppy ...
http://bootdisk.com/bootdisk.htm
Old 06-11-2006, 10:22 PM   #10 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Lightbulb Re: Floppy disk image ! ! !
@ax3
Here is the Solution if u want to take a image of a Floppy and Mount it later on the Floppy Disk
Floppy Image Creator 5 is a powerful utility that enables users to create images from the physical floppy disks, extract files or complete folders from a floppy disk image and create floppy disks from image files. Virtual floppy drive and creating of self-extracting (SFX) floppy image archives are supported as well. Floppy Image Creator is excellent software for creating floppy disks archives.
More Info HERE
Download HERE
I feel None would have known abt ever such a s/w existed for this work .I have used this s/w and it doesnt give any problems and it works really nicely and I hope u guys wont 4get to rep me 4 sharing this info
rakeshishere is offline
Old 08-11-2006, 06:09 PM   #11 (permalink)
ax3
ax3's Avatar
bt how 2 add smartdrive.exe 2 my exisiting 98bootable disk ? or just have 2 2click the file from
my hdd 2 work ....... as this file is imp 2 speed up installation process ........
ax3 is offline
Old 09-11-2006, 11:15 AM   #12 (permalink)
Come get Some
DukeNukem's Avatar
if your exisiting 98bootable floppy disk has enough space to hold that file then you can place the file in the floppy, then make an image of the floppy.
else
with floppy its not possible
why dont you try this
as i've told you before
make a floppy bootable by formatting it as bootable
format a: /s (this will copy system files in floppy)
then add the required files like exe's (i.e format, smartdrive.exe) and
the cd drivers to access the cd from dos.
thats it this is your customised bootable floppy for windows98
- by Krow
