Old 03-11-2006, 11:14 AM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Safe mode option ! ! !
wanna add safe mode option 2 my BOOT.INI file or get all the option when v press F8 ...... as i miss pressing F8 button @ right time .........
how can i add it ?
1 tut was present bt i couldnt find it out on this forum .........
ax3 is offline
Old 03-11-2006, 11:26 AM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Safe mode option ! ! !
Add following line in BOOT.INI :
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional Safe Mode" /fastdetect /safeboot:minimal /sos /bootlog
NOTE: change "multi(0)disk(0)rdisk(0)partition(1)\WINDOWS" according to ur system drive, where XP is installed
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 03-11-2006, 12:31 PM   #3 (permalink)
ax3
ax3's Avatar
thanx a lot ....... will add it 2 my ini file
ax3 is offline
Old 03-11-2006, 12:54 PM   #4 (permalink)
JGuru's Avatar
@Ax3, First make a backup of boot.ini before editing it!! If you make some mistakes while editing the
file, then Windows O.S won't boot!! If you create a backup copy in some other directory, you can always restore it easily.
* Imagination is more important than knowledge.
-Albert Einstein
JGuru is offline
- by Krow
