Nokia N72 Review
My personal experience -
KEYS - Keys are small and take time getting used to. You mite end up pressing the wrong keys esp while messaging. As music player button n 'c' r
placed v.close, u mite end up activating music player while messaging!
SPEED - The phone is v.fast. The applications open fast n there is hardly ne lag wit even more than one application open
HEADPHONES - Headphones are of excellant quality though cud hav been a little louder. But d bass/treble r produced at amazing quality.
CAMERA - 2 MP camera is awesome wit 20x zoom. There are quite a few clicking options. But red eye reduction is really missed here.
SLIDER - This one is a big pain and u wil end up sliding it accidently. For rough users be careful or u mite damage it.
SPEAKERS - Speakers r of decent quality & loud enough.
ACTIVE TOOLBAR - It is a v.useful utility n u can access ur fav. stuf rite frm main screen without having to browse deep in ur cel.
DOES THE PHONE HANG? - Against popular belief dat all d N series phones hav hanging prb., this phones have not hung even once
PC Suite n N72 Once u have installed PC Suite with d CD dat comes with N72 cell, browsing ur phone is just v.easy. The USB cable provided makes faster data transfer possible. U wudnt need a Mobtime Manager or odr s/w. to browse ur phone or install applications
VERDICT - 4.5/5
- 0.5 points coz of d keys n slider
SUGGESTION Plz get ur phone protected with
SCRATCHGUARD
PRICE apprx Rs.15200
General Source: nseries.com
Dimensions
Weight: 124 g
Height: 108.8 mm
Width: 53.3 mm
Thickness (max): 21.8 mm
Operating Frequency
EGSM 900/1800/1900
Automatic switching between bands
Memory Functions
Up to 20 MB* internal dynamic memory for contacts, text messages, multimedia messages, ringing tones, images, video clips, calendar notes, to-do list and applications
Expandable memory: 128 MB Reduced Size Dual Voltage (1.8/3V) MultiMediaCard (RS-MMC)**
Hot swap slot for easy MMC card insertion and removal
Approx. memory capacity indication with 128MB RS-MMC memory card
Photos (2 megapixel) up to 300 photos
* Changes to product details are possible without prior notice. Application offering may vary. Dynamic memory means that the available memory is shared
between dynamic memory functions. When any of these functions is used, there is less available memory for other functions which are also dependent on dynamic memory.
** Please note that the memory capacity of the reduced size MultiMediaCard (RS-MMC) in the sales package may vary depending on the market and/or your network operator/service provider.
Display and User Interface
Active standby main services always on top
On device photo editor and video editor (manual & automatic)
Large bright 2.1 inch (176 x 208 pixels) TFT color display with up to 262,144 colors
Ambient light detector - used to optimize display brightness and power consumption
Music key provides direct access to digital music player
S60 software on Symbian OS
Call Management
Speed dialing
Speaker Independent Voice dialing and commands
Nokia PoC (push to talk)
Contacts: advanced contacts database with support for multiple device and email details per entry, also supports thumbnail pictures and groups
Call logs: keeps lists of your dialed, received, and missed calls
Automatic redial
Automatic answer (works with compatible headset or car kit only)
Supports fixed dialing number, which allows calls only to predefined numbers
Conference call
See New - Mobile Photography and Video
Camera Specifications
CMOS sensor, 2 megapixel (1600 x1200 pixels)
Focus range 40 cm ~ infinity
Photography
2 megapixel camera (1600 x 1200 pixels) with up to 20x digital zoom
Slide for lens protection and camera activation
Integrated flash (operating range up to 1m)
Modes: auto, off, on
Advanced camera modes: still, sequence, video
Dedicated capture key
Scenes: automatic, user defined, portrait, landscape, sport and night
White balance: automatic, daylight, cloudy, tungsten, fluorescent
Color tone: normal, sepia, black & white, negative
Settings for brightness adjustment, image quality, self-timer, white balance and color tones
Video
Video: play, record, stream
Audio recording AAC
Video clip up to 60 minutes (limited by available memory)
File format .mp4 (high), .3gp (normal, MMS)
Video capture: 352x288 (CIF) at up to 15 fps MPEG-4
Automatic white balance control
Scenes: Normal, Night
Digital zoom CIF up to 4x
Editing
On device photo editor and video editors (manual & automatic)
Home photo editing on compatible PC with Adobe Photoshop Album Starter Edition
Nokia XpressPrint
Print digital photos directly from the device
Print images directly from the gallery
Transfer photos directly to a compatible printer, printing kiosk via Bluetooth wireless technology, a compatible reduced size MultiMediaCard (RS MMC)
memory card or to PictBridge-compliant printer via USB cable
Photo quality prints up to 6x4/15x10cm
Find out more at
www.nokia.com/xpressprint
Nokia XpressTransfer
Easily transfer your photos between your Nokia N72 and your compatible PC with Nokia PC Suite.
Connect to compatible PC and images and videos are automatically transferred with Nokia Image Store feature in Nokia PC Suite, and photo albums created on the device are saved in similar albums on the PC
Organize and edit photos and videos on a compatible PC with Adobe Photoshop Album Starter Edition
Deletion or resizing of the images and videos transferred from the device. Resizing means you can carry a large collection of photos and videos on your device and full quality versions are stored on the PC
Find out more at
www.nokia.com/xpresstransfer
Hear New - Mobile Music
Music Features
Music key for direct access to digital music player
Digital music player: supports MP3/AAC/eAAC/eAAC+ with playlists
Stereo FM radio (87.5-108MHz /76-90MHz)*
Visual Radio support, find out more at
www.visualradio.com
Nokia Stereo Headset HS-31, in-box
Nokia Audio Adapter AD-49, in-box
Nokia Music Manager application in Nokia PC Suite for music transfer
*Stereo sound can only be heard with a compatible stereo headset.
Do New - Mobile Computing and Connectivity
Productivity
Email client with attachment support (view jpg, 3gp, mp3, ppt, doc, xls, pdf files)
PIM (Personal Information Management): Contacts, Calendar, To-do, Notes, Recorder, Calculator, Clock, Converter, Printing
PC synchronization with Nokia PC Suite - Local/Remote (Windows 2000, XP)
Data: Calendar, Contacts, To-do, Notes, Email
PC applications: Microsoft Outlook (2000, 2002, 2003), Outlook Express, Lotus Organizer (5.0, 6.0), Lotus Notes (5.0, 6.0)
Anti-virus
Yahoo! Go
Setting Wizard
Browsing & Messaging
Internet browser: XHTML, HTML
Email (SMTP, IMAP4, POP3), MMS, SMS
Connectivity
Pop-Port interface with USB 2.0 full speed
Bluetooth wireless technology 2.0
Data Transfer*
EGPRS class B, multi slot class 10 (UL 118.4 kbps, DL 236.8 kbps)
Speech codecs supported: FR, EFR, and AMR
Data transfer application for moving data from compatible old Nokia S60 device over Bluetooth connectivity
*Actual achieved speeds may vary depending on network support.
Add-on Software
Operating system: Symbian ver. 8.1a
User interface: Nokia S60 2.8
Java: MIDP2.0
C++ and Java SDKs
Watch New - Media to-go
Stream media files from compatible media portals
RealPlayer media player
Download and play multimedia files (video and music)
Full-screen video playback on the device to view downloaded, streamed or recorded video clips in larger size
Played formats: AMR-NB, AMR-WB, AAC, RealAudio, RealVideo, H.263, MPEG-4
Package Contents
Sales Package Contents
Available colors: Gloss Black, Pearl Pink
Nokia N72
Nokia Battery BL-5C (970mAh)
Nokia Charger AC-3
Nokia Charger Adapter CA-44
Colour-coded Nokia Stereo Headset HS-31
Nokia Connectivity Cable CA-53
Colour-coded wrist strap
Cleaning cloth
CD-ROM: Nokia PC Suite & Adobe Photoshop Album Starter Edition
User Guides: User guide, Get Started guide, Get Connected guide & Additional Applications leaflet
Power Management
Operating Times*
Talk time (ECTEL): up to 215 mins
Standby time (ECTEL): up to 260 hours
Still images : up to 300 pictures (2 megapixel)
Music playback up to 9.7 hours (offline mode)
* Operation times may vary depending on radio access technology used, operator network configuration and usage.
