Old 02-11-2006, 06:33 PM   #1 (permalink)
Exclamation Any tools to time limit a PPT
HI,
is there any tool which can be used to embed a presentation file such that it can be opened till a certain number of days? like an expiry date for a presentation.
any clues here will be very valuable.
Thanks
Lets share our lives and enrich them.
ramborums is offline
Old 02-11-2006, 06:46 PM   #2 (permalink)
Wise Old Crow
blueshift's Avatar
Default Re: Any tools to time limit a PPT
Where you want to embed ppt files? Expiry date? I didn't understand.
One suggestion:Just delete the file completely after certain number days. It will work surely!
blueshift is offline
Old 02-11-2006, 07:33 PM   #3 (permalink)
The Devil's Advocate
iMav's Avatar
are u trying to do something like sending the file to some1 and he/she can only open it for say 1 week after that it cant be opened .... sometjing like a security feature??? .... if yes then sorry i dont hv any clue
http://beingmanan.com
iMav is offline
Old 02-11-2006, 09:32 PM   #4 (permalink)
You are right .. i am looking for a protection feature for a presentation. Like i want to be able to send a sample to someone but he should not be able to use the contents forever.
__________
Or would there be a way to atleast write protect a presentation .. something like what a pdf file is to a document?
Old 02-11-2006, 10:53 PM   #5 (permalink)
And if the user changes the date of the system, the protection will be lost, right?
Arun
sakumar79 is offline
Old 02-11-2006, 10:59 PM   #6 (permalink)
Wise Old Crow
blueshift's Avatar
There is no copy protect content feature inbuilt in PP but you can password protect and 'modify protect' the document.
In PP, goto Tools>Options>Security
Also before you save the file, fill all possible related information in File>Properties option and then in the Security tab in Privacy Options, check 'Remove Personal Information From File Properties On Save'.
- by Krow
