Old 01-11-2006, 09:48 PM   #1 (permalink)
Default Doubt Regarding AutoPatcher
Hi,
I have a doubt regarding Autopatcher... After a few months, I am finally patching up my system and rather than using MS's update, I decided to use Autopatcher's torrent download facility... Now, the full version is available for August only and other months, only updates have been issued... (With broadband connection, the full version took about 3 hours, possibly because it was extremely well seeded)
My question is, after installing full August version, do I need to apply both September and October updates or will October updates contain September updates also?
Arun
sakumar79 is offline
Old 01-11-2006, 10:27 PM   #2 (permalink)
Kiran.dks's Avatar
Default Re: Doubt Regarding AutoPatcher
Autopatcher XP October 2006 edition includes all updates of August 2006 and September 2006. Time to time critical updates are carried with every edition. So you need not install every month Autopatcher. Size of the Autopatcher will give an idea whether it is a full update carrying out all editions or few critical editions.
Here is the download link.
Kiran Kumar R
Kiran.dks is offline
Old 02-11-2006, 07:06 AM   #3 (permalink)
September and October releases are marked Updates.... And they are less than 50 MB in size... I want to know if October Updates will also contain September Updates...
Arun
Old 02-11-2006, 11:10 AM   #4 (permalink)
Kiran.dks's Avatar
Yes. October edition contains Aug and sep updates also.
Kiran Kumar R
Old 06-11-2006, 10:51 PM   #5 (permalink)
I think the question wud be if the October UPDATE file [not FULL FILE] wud contain september updates...
Not whether the october full file contains all previous windows updates or not...
thevilneo is offline
Old 07-11-2006, 06:51 AM   #6 (permalink)
Yup, and I recently read in a FAQ at http://www.neowin.net/forum/index.php?showtopic=410121 (link was posted in another topic), where it is mentioned that each update release must be installed after installing all earlier monthly updates... Therefore, the answer to my question appears to be NO...
Arun
- by Krow
