Old 25-12-2004, 01:37 PM   #1 (permalink)
Default can i use msn messenger on Redhat
Dear friends,
I have a special query.
I want to know whether I can use msn messenger on Redhat Linux for chatting. if not is there any other chatting software which can use my hotmail account.
I'll appreciate your quick responses.
regards,
Atul
striker_1909 is offline
Old 25-12-2004, 03:51 PM   #2 (permalink)
King of my own Castle
freshseasons's Avatar
I sugest you use AMSN
To down load it go here : http://sourceforge.net/project/showf...group_id=54091
1. Download amsn-0.94-linux-installer.bin
2. Enter a terimnal and allow execution permissions using "chmod 500 amsn-0.94-linux-installer.bin"
3. Type "./amsn-0.94-linux-installer.bin" and a graphical wizard will apper to help you in installation
4. "cd /opt/amsn-0.94" and then "./amsn"
Or if that dosn't worj you can also dothis.
make a symbolic link to /usr/local/ActiveTcl/bin/wish at /usr/bin/wish first (If uu are using ActiveTcl and u install it at /usr/local/ActiveTcl/) using "ln -s /usr/local/ActiveTcl/bin/wish /usr/bin/wish" and try again
If it works, u can use aMSN throughe the desktop shortcut
To start aMSN from the command line, do "ln -s /opt/amsn-0.94/amsn /usr/bin/amsn" and u,will be able to start aMSN using "amsn" .
Hope that helped you !
Best Luck and Merry Christmas !
freshseasons is offline
- by Krow
