Old 25-12-2004, 12:53 PM   #1 (permalink)
vysakh's Avatar
Default NO BALL in cricket 2002
i got this old game 2 days back. the problem is that when i ball, it is a no ball. how do i correct this???
Incompatible message format
vysakh is offline
Old 25-12-2004, 04:05 PM   #2 (permalink)
cool_dude_prav's Avatar
Default correction
hey vyshak you must press the button twice before he reaches the crease or else, it will be a no ball.....
The Bloglines of an Angry Indian -
www.angry-indian.com
If only life were as easy as Ctrl+Z (undo) and F4/Ctrl+Y (redo)...
cool_dude_prav is offline
Old 25-12-2004, 07:23 PM   #3 (permalink)
vysakh's Avatar
which button?
vysakh is offline
Old 26-12-2004, 08:39 PM   #4 (permalink)
Ethan_Hunt's Avatar
The Key With Which U ball Has to be pressed twice..... i.e when the Bowler actually reaches the crease press the Bowling button again so that He Has to bowl the Actual ball then.....Plus u alos have to set the marker which marks the Point where the ball is gonna be pitched.....make sure its in the middle stump aim or may be somewhere close to it.... 8)
Ethan_Hunt is offline
Old 26-12-2004, 10:27 PM   #5 (permalink)
CCIE# 20863
Originally Posted by vysakh
which button?
U can configure the buttons in options->Controller
The key is same as of the key used while batting. As allwyndlima said, u need to press it twice.
Bugs can neither be created nor be removed from software by a developer. They can only be converted from one form to another. The total number of bugs in the software always remain constant.
theKonqueror is offline
Old 27-12-2004, 02:42 AM   #6 (permalink)
Laptoping
Sourabh's Avatar
@vysakh
dun mind but to b frank u r way ahead of times in terms of games u play and the time at which u get them
wonder how can u do tht so frequently :roll:
Sourabh is offline
- by Krow
