01-11-2006, 04:17 PM
Cool as a CUCUMBAR ! ! !
Disk defragmentation ! ! !
i use default windows defrag tool which takes lot of time 2 perform its task ......
any other freeware option (software) ?
which 1 do u use & is it speedy enough ?
01-11-2006, 04:36 PM
gooby pls
Re: Disk defragmentation ! ! !
Try Diskeeper 2007,it improves overall system performance.
01-11-2006, 04:38 PM
Default windows defragmenter is slow and resource hug. Diskeeper is very popular defragmenter. But it is a paid version. You can download 30 day trail pack from here. Diskeeper 2007
After that what? No problems, here is a link for free Download of Auslogics disk defragmenter. It is a popular one and totally free!
Auslogics Disk Defrag 1.0.3
Kiran Kumar R
01-11-2006, 05:50 PM
Diskeeper 2007 ....... is it provided in any digit cd ....
01-11-2006, 06:09 PM
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
01-11-2006, 06:53 PM
01-11-2006, 07:40 PM
Rebooting
no matter what tool u use to do a proper defrag in FAT file system it will take a lot of time...
if u r in Windows 2000 or XP or Vista ... make sure u r in NTFS file system... here it will take a lot less with Windows Default tool...
rebooting
ChotoCheeta.com
01-11-2006, 07:46 PM
Tux Fan
NTFS is definately faster and you also get added security fetures.
Using the default windows defrag tool I can defrag my 80gb NTFS drive in bout 15~20 mins but earlier [when it was in the FAT file system] it used to take roughly 1.5~2hrs.
Cheers
Shaunak
Feel free to PM/email me.
01-11-2006, 07:52 PM
Rebooting
that sums it up...
also one more thing... If u defrag a Drive with 0 files in it... it will be faster... but while u r defraging a drive with 90% full... well it will take more....
rebooting
ChotoCheeta.com
02-11-2006, 10:57 AM
Raxco's PerfectDisk is the best defrag software out there, but it's a paid software. Give it a try.
If you're looking for a free option only, then stick to the defrag utility that comes by default in win xp, it's also okay.
02-11-2006, 11:10 AM
a_g = JPKN
@piyush619, what does Tune-Up Utilites has to do with Defragmentation.
it has only "Registry Defragmenter" & not file defragmenter.
ASUS K53SV SX520D + BF3
02-11-2006, 12:16 PM
Distinguished Member
defragging in safe mode with the windows defragger can also reduce time...
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
02-11-2006, 03:49 PM
AFK
Try using Auslogics Disk Defrag or diskeeper(may its available at softpedia.com)
02-11-2006, 05:12 PM
The Researcher
Whenever I defrag my drivwe with NTFS, it hardly takes 5 minutes. I am running winxp pro sp2
02-11-2006, 05:30 PM
5 minutes is too low to believe! May I know the frequency of defragmentation? How often you do it?
I doubt that Defragmentation is not 100% successful.
Kiran Kumar R
02-11-2006, 05:49 PM
& how often it should b done ?
as i do it after 7-8 months .......
02-11-2006, 06:14 PM
I use defrag in XP and it takes only 2-4 minutes. May be because I do it frequently. I also occasionally use Sys Mechanic for the same purpose.
V.Prem Kumar
02-11-2006, 06:23 PM
a_g = JPKN
@ax3, it depends on the way you use your PC.
If you do lot of Video Editing, Game Modding, Creation/copying of Files..., then you may have to Defragment Frequently.
Just stick to what The DEFAULT MS Defragmenter advices, whether the drive needs Defragmentation. (for this select the drive & press "Analyze")
02-11-2006, 08:31 PM
#19 (permalink)
Rebooting
one more thing i have noticed while defragmenting if a AVS auto scanner is on.. its takes more time.. while if u turn of the Auto file scanner of running AVS it takes lot less... both with FAT and NTFS file system...
rebooting
ChotoCheeta.com
03-11-2006, 05:52 PM
#20 (permalink)
The Researcher
At least twice a week. You should see experience my PC, then you will agree with me that I have maintained very well
25-11-2006, 09:04 AM
#21 (permalink)
how different is Auslogics Disk Defrag or any other defrg tool from NORMAL windows defragging tool ?
ie performance wise : how can it perform faster than normal 1 ?
25-11-2006, 07:53 PM
#22 (permalink)
I use perfect disk
26-11-2006, 11:01 AM
#23 (permalink)
i have installed & TRY Auslogics Disk Defrag ...... it defraged my all drives in FLAT 35 min ie 7 min/ drive ........
cool ....... bt didnt experience any change ?
did it really DEFRAG my drive ?
26-11-2006, 01:39 PM
#24 (permalink)
Hanging, since 2004..
I recommend O&O defrag.
Windows 8 ? :lol:
I have a better OS installed, people call it Windows7 8-)
27-11-2006, 11:17 AM
#25 (permalink)
Šupər♂ - 超人
I use a single sw to look after all my system probs... The System Mechanic
One stop solution for all disk utilities... It has an excellent disk defragmenter too.
Ya... it costs 50$
27-11-2006, 12:51 PM
#26 (permalink)
Come get Some
well use any deragger (i prefer and user disk keeper)
but do one thing before defragging.
dissable hibernation before defragging and enable it after defraging completes
reason > The Hiberfil.sys file, which can be very large, is a special system file that Disk Defragmenter cannot defragment. Therefore, the presence of the Hiberfil.sys file will prevent Disk Defragmenter from performing a thorough defragmenting operation.
more on
Cool Defrag Info
Computers are like Air Conditoners, thet stop working properly when u open WINDOWS.
27-11-2006, 01:10 PM
#27 (permalink)
more on
Cool Defrag Info
Use Diskeeper 2007. It can defragment comfortably in any condition. It's real-time defragmenter is awesome! Unarguebly, the best one I have ever seen. Just install it and forget it, rest of the things diskeeper does it automatically!
Kiran Kumar R
08-12-2006, 05:13 PM
#28 (permalink)
Auslogics Disk Defrag ........... just ROCKS ! ! !
fast, effective & free
08-12-2006, 05:46 PM
#29 (permalink)
The pWnster
i wud recommend diskeeper for paid
and auslogics for freeware
Sigs suck
09-12-2006, 08:05 AM
#30 (permalink)
From my personal experience i would recomend pepole not to go for O&O Defrag. I had very tough time with it because it doesn't defrags ystem mea data file and caused my PC to have a maximum simultaneous space to 500mb and a highly fragmented system. Then I swithced to perfect isk and it fixed the problem
Search this Thread |
