Old 01-11-2006, 09:25 AM   #1 (permalink)
Question DVD Region Code
I have LG DVD Writer and i played "The Matrix" DVD of USA Origin(Region 1). so my DVD Writer region set to 1. if i play Indian DVD then What will happen? if my DVD Writer change code for 5 times then what will happen? if my last code is Indian then Can i Play DVD of USA?
bhoolkumehul is offline
Old 01-11-2006, 10:16 AM   #2 (permalink)
Default Re: DVD Region Code
after 5 times...the final region code will be locked for ever!!! i've no idea if there is any hack way for this...change it again.
jack// ani is offline
Old 01-11-2006, 10:28 AM   #3 (permalink)
Welcome To The Jungle
sysfilez's Avatar
y do u have to change the region code?
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 01-11-2006, 10:53 AM   #4 (permalink)
obviously this guy...must be playing original dvd that why!!
Old 01-11-2006, 11:02 AM   #5 (permalink)
dIgItaL_BrAt's Avatar
use AnyDVD
dIgItaL_BrAt is offline
Old 01-11-2006, 11:05 AM   #6 (permalink)
sysfilez's Avatar
ok maybe that was the reason y i cudn't play a Uk based dvd of Led Zeppelin.
sysfilez is offline
Old 01-11-2006, 11:35 AM   #7 (permalink)
busyanuj's Avatar
yes, after the 5th change, the last region setting will become permanent.
you can check at the LG website if they've released any new firmware for your drive which probably makes your drive region free (although this is a remote possibility).
busyanuj is offline
Old 01-11-2006, 11:37 AM   #8 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
it is 5 or 3 ..i am confused..check with the company
wizrulz is offline
Old 02-11-2006, 12:47 AM   #9 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
Originally Posted by dIgItaL_BrAt
use AnyDVD
cool this works fine
Blogging @ http://classictutorials.com
the.kaushik is offline
Old 02-11-2006, 01:11 AM   #10 (permalink)
aku
Gonna make it BiG
aku's Avatar
Location: Familiar with Java... SORRY POINTER NOT ALLOWED!!!
u cn also use dvdregionfree. Btw btw u can unlock ur drive (aftr da 5th chng) 2 times, ie. 1st by da end usr, 2ndly by da manufacturer. Therefore a total of 7 / 15 changes r posibl.
aku is offline
- by Krow
