Old 30-10-2006, 02:15 PM   #1 (permalink)
The Researcher
Default prevent copying of data cd
Recently I purchased Oxford Advanced learner's dictionery with CD. Now when I tried to copy it or make an iso image of it, it is not allowing to be copied. I want to know how this can be done and by what software.
Ramakrishnan is offline
Old 30-10-2006, 02:20 PM   #2 (permalink)
kl_ravi's Avatar
Default Re: prevent copying of data cd
Now if your intentions are good and you want to make a backup copy of your original disk, you can use Alcohol120% or Blindwrite ....
Remember sharing the backup cd with your friends or running it on more than one computer amounts to piracy which is forbidden here.
Everything that follows is a result of what you see here...!!!
kl_ravi is offline
Old 30-10-2006, 02:31 PM   #3 (permalink)
Come get Some
DukeNukem's Avatar
Cool Re: prevent copying of data cd
After trying all options mentioned above
Try This
I've done it with winimage(use any alternative) and Virtual CD (ver.7)
1.> First make an iso image of your CD with winimage. yes it will not get done. (do not delete the incomplete image, it has all the structure/info. needed to create virtual cd of protected CD's)
2.> now insert this image using Virtual CD in your virtual Drive.
3.> Create Virtual CD of the Inserted Incomplete image. (Allow Virtual Cd as Source for this option in Virtual Cd settings)
4.> now edit the created virtual cd using the virtual CD editor. (Open .vc4 file for editting)
5.> now copy your cd to any folder in HDD
5.> copy all files to the editing virtual cd (replacing all existing files)
6.> Then Create virtual cd from the editor itself.
Thats it. this method will save your existing Genuine CD from gettin Scratchs
I've successfully created virtual cd of Dungeon Seige, Mech Warrior (get with my HCL PC) and DukeNukem Project Manhettan usin this method.
Computers are like Air Conditoners, thet stop working properly when u open WINDOWS.
DukeNukem is offline
Old 31-10-2006, 09:19 PM   #4 (permalink)
Resident Fanatic
Manshahia's Avatar
what if we want to make our CD protected like that. Is there any software that can prevent a cd being copied?
__________
Yaar bata do hai koi esa software?? jis se hum CD copy hone se rok sakte hain? or ya phir uska hide kar sake taki kissi ko pata hi na challe.
Manshahia is offline
Old 31-10-2006, 11:05 PM   #5 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
__________
ya.. i think this is the question being asked.. same question is it possible to make protected data cd?
Blogging @ http://classictutorials.com
the.kaushik is offline
Old 31-10-2006, 11:34 PM   #6 (permalink)
Resident Fanatic
Manshahia's Avatar
Koi to reply karo bhai
Old 01-11-2006, 12:02 PM   #7 (permalink)
Come get Some
DukeNukem's Avatar
Hyper-Active User in the Forum
Search the form Hyper-Actively
Old 01-11-2006, 12:37 PM   #8 (permalink)
The Researcher
I also wanted to know how cd can be copy protected. For everybody's info, the suggested software, i.e. Blindwrite cannot copy the protected cd. Can anybody give me the names some software/methods through which we can protect data/audio cd/dvd's?
Old 01-11-2006, 03:06 PM   #9 (permalink)
busyanuj's Avatar
try Alcohol 120% as already suggested above.
busyanuj is offline
Old 02-11-2006, 10:35 AM   #10 (permalink)
kl_ravi's Avatar
Oxford Advanced Learner's Dictonary is protected by CD-COPS Copy protection.
http://linkdata.com/index.htm#news11
http://www.linkdata.com/index.htm#cdcops
I guess Blindwrite tries to make 1:1 copy regardless of the contents its trying to copy. That's why its called blindwrite.
kl_ravi is offline
Old 02-11-2006, 09:57 PM   #11 (permalink)
a_g = JPKN
s18000rpm's Avatar
go here. a tutorial " Make copy protected CD's" posted by a thinkdigit member "khattam_"
Make Copy Protected CD
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 03-11-2006, 12:26 PM   #12 (permalink)
The Researcher
The above tutorial is for copy protecting linux cd's. How about making windows data copy protection?
Old 03-11-2006, 12:36 PM   #13 (permalink)
Come get Some
DukeNukem's Avatar
Talking Re: prevent copying of data cd
Why do you wana make your cd's copy protected . what's sooooo important.
first you guys wanna copy copy protected Cd's. then you wanna make cd's copy protected
but then thats human nature
that's why there's a phrase in hindi " @#$%% ki puch kabhi sidhi nahi hoti"
Old 06-11-2006, 12:52 PM   #14 (permalink)
if anyone knows it....dont reveal here.......go directly to microsoft and tell bill g@te$....
__________
BTW i know a "JUGAD" to hide the cd contents in all..even "show all files" will fail....u wanna know?
__...:::---*Keyboard Cowboy*---:::...__
whistler is offline
Old 06-11-2006, 02:35 PM   #15 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
nice whistler!!
Without sorrows happiness would be boring!
romeo_8693 is offline
Old 06-11-2006, 06:30 PM   #16 (permalink)
seriously i know the jugad....i have been using it for a while......
whistler is offline
Old 06-11-2006, 07:00 PM   #17 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
I know a bit of this stuff but i would like to see what others reply in here
rakeshishere is offline
Old 07-11-2006, 02:51 PM   #18 (permalink)
hansraj's Avatar
hey whistler can u come up with u r JUGAD!!!!!
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
- by Krow
