Old 30-10-2006, 07:58 AM   #1 (permalink)
Default Installation Error
Why This Error???
Whenever I try to install an interactive program for kids, I'm getting
an error message as given below.
"The InstallShield Engine (iKernel.exe) could not be launched.
The RPC server is unavailable."
Why this error?
Please help me soon.
Raaza is offline
Old 30-10-2006, 09:46 AM   #2 (permalink)
:-o
aakash_mishra's Avatar
Default Re: Installation Error
Click Start, click Run, type the following line in the Open box, and then click OK:
net start rpcss
www.amiable.in
aakash_mishra is offline
Old 30-10-2006, 07:38 PM   #3 (permalink)
nothing happens good
the same error report again and again
is there any other method?
the program is "Jumpstart advanced 1st grade" for kids.
it's two clonecd image files, got via torrent, size is 893 mb.
please help me coz it'd taken several hours to download the files via utorrent.
thanks in advance
Raaza is offline
Old 30-10-2006, 08:06 PM   #4 (permalink)
:-o
Try updating your InstallShield Engine
www.amiable.in
Old 30-10-2006, 09:40 PM   #5 (permalink)
how can I update InstallShield Engine?
pls give me the details
thnx
Raaza is offline
Old 30-10-2006, 10:10 PM   #6 (permalink)
:-o
Thumbs up Re: Installation Error
Update it by following instruction over here
www.amiable.in
Old 30-10-2006, 10:49 PM   #7 (permalink)
hi dear friend,
before you post this reply I myself found this article when googled it.
Then i tried to update installshield, the file version number was 2.0x or less ie (1.1.01)
So I downloaded the "IkernelUpdate.exe"
i couldn't update the same. simply those were not successful.
I found another article http://www.laplink.com/support/kb/article.asp?ID=671
I tried their method too.
but not succeeded
So
I simply browsed to the file "C:\Program Files\Common Files\InstallShield\Engine\6\Intel 32\IKernel.exe" and opened it,
interestingly enough I could install the software very successfully,
even if your suggestions didn't help me directly, I thank you coz your advice directed me myself to find the solution itself. thanx for others support too.
Raaza is offline
- by Krow
