Old 30-10-2006, 07:12 AM   #1 (permalink)
ArZuNeOs's Avatar
Default renaming Woes !!!!
I had my bday party Video in .Avi format
I Accidentally changed it to .RAR format by simply renaming it
Can u tell me how to Change it BAck Guys
Help me Out
Back to the world of realms
ArZuNeOs is offline
Old 30-10-2006, 08:26 AM   #2 (permalink)
Come get Some
DukeNukem's Avatar
Default Re: renaming Woes !!!!
First
If your file name is like this Filename.rar just replace "rar" with "avi" (if "hide extensions for known file types" is dissabled)
else
open command prompt then browse to that folder
then issue this command
"ren filename.rar filename.avi" (without " ")
Simple
and if "hide extensions for known file types" is dissabled then i suggest you to enable it.
how? here are the steps
open any window/folder
click on tools from menu
click option "Folder Options.."
choose "view" tab
here you will find "hide extensions for known file types"
enable it if it is dissabled
thats it.
Computers are like Air Conditoners, thet stop working properly when u open WINDOWS.
DukeNukem is offline
- by Krow
