Old 29-10-2006, 11:16 PM   #1 (permalink)
God of Mistakes...
Garbage's Avatar
Red face Acronis True Image problem
Hi guys!
I've installed the Acronis True Image trial. It wows!
Now I've just installed WinXP on another drive. 'n I've created a Backup of that partition (in case I want to restore my XP)
But the backup size is abt 800 MB.( not fitting in a CD )
What can I do now? Can I create a CD from which I can restore XP ?
Plz help !!!
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 30-10-2006, 12:18 AM   #2 (permalink)
JGuru's Avatar
Default Re: Acronis True Image problem
Get a 800 MB CD dude & take a backup. It should solve your problem.
EuroVision 800 MB CDs are available in the market. Yes, you can restore
XP from the CD.
* Imagination is more important than knowledge.
-Albert Einstein
JGuru is offline
Old 30-10-2006, 02:06 PM   #3 (permalink)
The Researcher
Another solution is use backup splitting in the options menu. It will allow you put the backups in different cd's. If the back up is 1024Mb, then it will be stored in two cd's and you can restore from these cd's
Ramakrishnan is offline
Old 30-10-2006, 08:48 PM   #4 (permalink)
God of Mistakes...
Garbage's Avatar
Thanx for suggestion guys!!
I'll try to get 800 MB CD. But I don't think I'll get it here
It's nice to split backup. But What if I want to keep it on a CD. Can't I compress it any more??
Garbage is offline
Old 30-10-2006, 08:53 PM   #5 (permalink)
Tech Geek's Avatar
use winzip after splitting
Tech Geek is offline
Old 31-10-2006, 04:04 AM   #6 (permalink)
El mooooo
eddie's Avatar
Depending on the version you are using, Acronis gives you various built-in compression options. You can choose the "maximum" (or highest?) level and save some space. The best option is to split your backup files. As time goes, you will install more software and the backup size is bound to increase...then no amount of compression will help you. Its better that you get used to making split backups
eddie is offline
Old 31-10-2006, 08:13 AM   #7 (permalink)
You may find this link useful
http://www.neowin.net/forum/index.ph...acronis+backup
joe2005 is offline
- by Krow
