i have a broadband connection n i once surfed without the firewall turned on,, n now i m not able to use the run command n sometimes the task manager,, n i cant edit my registry,,,, moreover,, a status message telling others to click on some coolpics.com link is appearing in my yahoo messanger n it sends this message rite in front of me automatically to the ones wid whom i m chatting,,,.. in my IE6, the home page is set to coolpics.com,,, (dat i managed to change it)
i ran spybot search n destroy n i found something called browser embedded something,,,, n i deleted it twice still all the above mentioned problems occur,,,
can u tell me which spyware/virus m i infected with n how to remove it??
thanx
