Old 29-10-2006, 05:53 AM   #1 (permalink)
zero's Avatar
Red face Can we Save the Updates?
Hi everyone,
I use XP SP2 with windows automatic updates set to "Download but ask when to install" and Norton Antivirus is set to LIve Update itself.
I have a total updated system now I wish to know if Suppose I wish to format my system is there anyway to carry the updates to the next install from present install.
U may say to download updates individually and then to keep them for future But Norton will give me the definition downloads only and in windows updates I'll be on my own to decide which one's I want.
Is there a way to save the updates which are automatically downloaded to my system before I choose to install them manually.
I hope I could explain myself clearly if anything not clear kindly drop ur comments I'll edit the post.
zero is offline
Old 29-10-2006, 07:09 AM   #2 (permalink)
The CREATURE
zodiac_511's Avatar
Default Re: Can we Save the Updates?
One way is to update windows manually making note os the update numbers (eg KBXXXXX) Then search the ms site for it and download it.
Another easier option is To use Autopatcher XP (www.autopatcher.com)
This is available on most digit DVDS
..::: ||ZoDiAc|| ::..
zodiac_511 is offline
Old 29-10-2006, 12:24 PM   #3 (permalink)
Ya Autopatcher is a nice option. U may find it on DVD or download it from here
http://autopatcher.fbdn.net/
prabhatmohit is offline
Old 29-10-2006, 02:33 PM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
All updates r stored in following folder:
%windir%\SoftwareDistribution\Download
Just copy paste all folders under it and then run update.exe file to install updates again
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 29-10-2006, 07:00 PM   #5 (permalink)
Hell Sucks!!!
Hey Vishal, there r so many updates, do we need to run setup of each one individually ???
ashu_dps is offline
Old 29-10-2006, 08:51 PM   #6 (permalink)
Microsoft MVP
Yes!
Old 30-10-2006, 08:38 PM   #7 (permalink)
Hell Sucks!!!
Can anyone find a way to install all the updates automatically as windows update service does ?
ashu_dps is offline
Old 30-10-2006, 08:51 PM   #8 (permalink)
Microsoft MVP
You can create a batch file or use nLite to integrate in the Setup
Old 30-10-2006, 09:38 PM   #9 (permalink)
Hell Sucks!!!
Thnx for the info vishal, bt can u plz elaborate the steps. Thanks
ashu_dps is offline
Old 02-11-2006, 12:22 AM   #10 (permalink)
zero's Avatar
Thumbs up Re: Can we Save the Updates?
Thanks for the Info I wanted that Only ... anyway as of Now I've reinstalled the system will do automatic updates and then will take a GHOST backup of partition so that next time onwards I'll start at least here upwards.
zero is offline
Old 02-11-2006, 01:16 PM   #11 (permalink)
Distinguished Member
anandk's Avatar
also check Saving Windows Update Files.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 21-01-2008, 07:29 PM   #12 (permalink)
thanks alot for the info. I think backing up %windir%\SoftwareDistribution\Download will be a better idea as autopatcher installs too many of the updates .. Last time i installed it my system starts to become unstable. Maybe because of some other thing but i'll stick to the downlad that is there in my computer .
Experience Is not Counted in Years.. But in the Countless Effort
www.kolasib.com www.zoram.org
valtea is offline
- by Krow
