Old 28-10-2006, 11:34 PM   #1 (permalink)
subhajitmaji's Avatar
Question Putting the monitor on StandBy
I dont want to wait for 1 minute to put my monitor at Standby. Neither I want to switch off the monitor by pressing the monitor power button.
Are there any software which can help me to put my monitor at standby instantly.
Can I do the same manually, i.e., without using any 3rd party software.
Driving on the highway is not a competition. It is a co-operation, the sharing of a limited resource.
subhajitmaji is offline
Old 29-10-2006, 12:11 AM   #2 (permalink)
gaurav21r's Avatar
Default Re: Putting the monitor on StandBy
Why do you wait for one minute? Just click Start-> Turn Off -> Standby
do i have to write something here?????
gaurav21r is offline
Old 29-10-2006, 12:14 AM   #3 (permalink)
basically, install the program, the option "monitor standby" should be in the "more programs" group. run it, monitor will suspend - apon resume you will be confronted with a button to return you to mce, click/press OK on remote, and you will be returned to mce.
any suggestions or problems, just post back here - basically it works for me, and thats all im mostly concerned about, but..... i take no responsibility if this fancy program causes damages to your computer/monitor etc. be it hardware or software damages.
thought i might cover myself
few quick notes: dotnet1.1 framework required - also, just to clear things up, make sure you dont have mce set to be "always on top" in the startup and window behaviour options (might be a problem). all shoudl work well - my friend has on issue..... works for me, i got no one to test it with.
Download: http://www.users.tpg.com.au/iconeo/m...standbyMCE.msi
Source: http://thegreenbutton.com/forums/thread/35581.aspx
–•(–•Raghav™•–)•– is offline
Old 29-10-2006, 01:05 AM   #4 (permalink)
aadipa's Avatar
here is what you need - just a small 75 kb application.
http://www.thinkdigit.com/forum/show...5&postcount=10
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 29-10-2006, 01:20 AM   #5 (permalink)
gaurav21r's Avatar
i dont get it what subhajitmaji is tryin 2 do is to simply put the system in standby. Why do u need 3rd party tools. Someone Kindly xplain..
Old 29-10-2006, 11:39 AM   #6 (permalink)
@gaurav21r
You hv not understood my question. I dont want to put the system at standby, i just want to put the monitor on standby with all the tasks running.
__________
@aadipa
Thanks buddy. It works. Gr8 tool indeed. I just asked a question and got answer of many questions.
Last edited by subhajitmaji; 29-10-2006 at 11:39 AM. Reason: Automerged Doublepost
- by Krow
