Old 24-12-2004, 04:22 PM   #1 (permalink)
t3h g04t
teknoPhobia's Avatar
Default Serious graphic problem...need help quick...desperate
I need a fix for the problem that Nvidia driver v56.xx and up cause when used on a km133. I bought a FX5700 today and release 53.xx doesnt support the FX5700...I cant afford a new mobo right now...so if neone has any solutions...apparently this problem has been reported before but other than MS acknowledging a bug in ddraw I cant find anything else...I'll be really glad if anyone could help.
problem description: d3d and ddraw hang up the system in fullscreen mode...windowed mode works fine.
System: AthlonXP 1800+(palomino) km133 based mobo 256mb sdram..cmedia 8738 soundcard..realtek lan..one of the standard chips..I forget which
I do realize that this shud prbly be in the software section but plz bear with me
teknoPhobia is offline
Old 28-12-2004, 01:15 AM   #2 (permalink)
why dont u just download the latest drivers from nvidia.com, i think 77.?? was the latest. might fix ur problems.
the_apocalypse is offline
Old 28-12-2004, 03:56 AM   #3 (permalink)
You need to install the VIA Hyperion Drivers (4 in 1 ) latest version , can find it at www.guru3d.com , should help , i had kle133 before from MSI
AMD64 2800+ 1GB ECC DDR 400 ,MSI K8T800 Asus Geforce FX 5200 128 MB, 120 GB Barracuda,16X DVD RW,Samsung 16x DVD,Samsung Wireless ,Creative AUDIGY2 ZS 7.1 with Creative Inspire 7.1/1800+AXP 512MB ECC DDR400 .40GB BLACK
indro is offline
- by Krow
