Old 27-10-2006, 06:02 PM   #1 (permalink)
Default Using PNG file to draw form shap and transparency
Hi,
Anyone knows code to draw form shape using png file also it should be transparent where png file has transparency.
To be more clear i want code in VB in which I will use PNG FILE WHICH HAS TRINGULAR GRAPHICS, I WANT my form to be tringular and where there is no triangle that portion to be transparent.
rajesh_nk22 is offline
Old 28-10-2006, 12:50 PM   #2 (permalink)
aadipa's Avatar
Default Re: Using PNG file to draw form shap and transparency
This MSDN link may be helpful to you.
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
- by Krow
