Originally Posted by vikasg03
What do you mean by genuine??? in INDIA 99% is pirated. And dear one more thing concept,starting and end of the movie is same whether it is original or pirated CD/DVD. Means if in any movie the hero won finally in original DVD then it doesn't die in pirated?.......
Anyway I always purchase "SO CALLED PIRATED DVD" sometimes it blue color but never found this error.
VIKAS
So its pirated.
Pirated movies are burned on cheaper media at higher speeds which may result in the disk being improperly burnt. There is nothng wrong with you codecs. The disk is at fault.
What do you mean by "so called pirated"? It is either pirated and you are a thief, or it isnt. End of story.
Do you know just because "99.9%" people [according to you] buy pirated disks, the rest 0.1% who do buy original stuff have to pay exhorbant rates.
http://www.piracyisacrime.com/
Piracy is a crime.
And "everyone does it" is not a very good excuse.
