Old 26-10-2006, 12:45 AM   #1 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
Unhappy HDD formattin prob......
i hv a 160gig hdd, wich got a partition of 40gb only 4 movies. but 4 past few days its bcom a bit unresponsive. wen i tried 2 format it, i got tthis error:
Windows was unable to complete the format
also, wen i tried d same frm the command prompt, i got this error:
Cannot open volume for direct access.
wat do i do? wats rong wit my hdd? n wat abt my movies??????????
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 26-10-2006, 01:50 AM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: HDD formattin prob......
Dont panic, I have a partiton of 66 GB !! For ur problem, it seems that the files on that partition were being used when u tried to format it! Either the page file was located there or u were playing some media file locate in that partition or something like that!
Be sure that the partition is not being used in neway before formatting!
mediator is offline
Old 26-10-2006, 09:52 AM   #3 (permalink)
Back to l33ching :)
but i m nt using d partion in ne way
Old 26-10-2006, 04:42 PM   #4 (permalink)
Come get Some
DukeNukem's Avatar
From where are you formatting the HDD
I MEAN OS/PLATFORM
DukeNukem is offline
Old 26-10-2006, 04:52 PM   #5 (permalink)
String Phreak
mediator's Avatar
@gaurav : U may try using the format tool in control panel > admistrative service > computer management then!
mediator is offline
- by Krow
