Old 25-10-2006, 08:27 PM   #1 (permalink)
Default is this the end of my hdd?
hi guys today when i was playing project igi my pc hanged during loading n when i restarted there is no response pls tell me what to do now thanks
EVERYBODY WANTS TO GO TO HEAVEN BUT NOBODY WANTS TO DIE
mandar5 is offline
Old 25-10-2006, 09:04 PM   #2 (permalink)
JGuru's Avatar
Default Re: is this the end of my hdd?
@Mandar5, How old is your HD? Just check whether your HD is being detected by the BIOS.
* Imagination is more important than knowledge.
-Albert Einstein
JGuru is offline
Old 25-10-2006, 09:19 PM   #3 (permalink)
my hdd is 2 yr old and even my monitor refuses to start n cd drive dont open
mandar5 is offline
Old 25-10-2006, 09:24 PM   #4 (permalink)
bang bang!
Chirag's Avatar
Well try taking out the CMOS Battery and start or try putting the ram in another slot.
Chirag is offline
Old 25-10-2006, 09:27 PM   #5 (permalink)
It need not be your hdd only that is the cause of the problem. If you are getting any beeps from your system(if your system speaker is up) while boot up then it means either your ram needs to be readjusted (plug it out and then in again). If you have a graphics card then check that one too, 'cos it too creates problem of that sort although the beep count is different. The main reason why I don't suspect a prob with your hdd is that the display itself doesn't come up .. now if your hdd was the problem, the display shoudn't be affected!!!!
sridhar8310 is offline
Old 25-10-2006, 10:06 PM   #6 (permalink)
thanks 4 the replies guys i will call my dealer tomorow
mandar5 is offline
Old 26-10-2006, 10:06 AM   #7 (permalink)
try replacing ur SMPS
NagpurDaMunda is offline
Old 26-10-2006, 02:44 PM   #8 (permalink)
thanks guys 4 advice when i turn on pc the green light of cabinet is on but not red one also my speaker light turn on but monitor doesnt do u think i have messed with log off button?thanks
mandar5 is offline
Old 26-10-2006, 04:18 PM   #9 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
i think if u dont know much abt self servicing then u should take the PC to a computer dealer.. they will check out the whole thing and tell u what part has gone bad. i think most prob it is ur mobo.
Rollercoaster is offline
Old 26-10-2006, 04:28 PM   #10 (permalink)
Come get Some
DukeNukem's Avatar
Try Removing the data cable of your HDD and then start your Computer.
then turn it off
then plug the data cable of the HDD Again
Well it works for me when i faced the same Probs. while playing dinosaur
DukeNukem is offline
Old 26-10-2006, 06:39 PM   #11 (permalink)
absolutely im chemistry student n dunno much of pc
__________
why i dont want to show problem to dealer bcoz last time he charged 350rs just to run xp recovery console n recover a corrupted file due to which xp wasnt starting:-l
mandar5 is offline
- by Krow
