Something strange has been happenning aftr i reinstalles xp last week.
First aftr reinst xp i updated it to sp2 but later uninst it.Then it was working fine for the past few days.
But since past two days when ever i right click on a file the explorer(shell) restarts the start bar goes off and resets the folder which is open closes but the progs which are running stays.It happens only wen i right click on files (exe jpg mp3 etc)
wen i rght click on folders nothing strange happens the normal rght click options come up.But it goes crazy with files.Also its normal with shortcuts program menues etc.The only prob is seen with the files.
I have tried disablin all start up stuff scaned for virus using stinger .
Here is the hijack tis log:
Logfile of HijackThis v1.97.7
Scan saved at 12:25:26 PM, on 12/23/2004
Platform: Windows XP (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 (6.00.2600.0000)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\System32\Ati2evxx.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\MultiRes\MultiRes.exe
C:\Program Files\In2Cable\CMAAClient.exe
C:\Program Files\Mozilla Firefox\firefox.exe
C:\WINDOWS\explorer.exe
J:\downloads\edonkey\HijackThis.exe
O4 - HKLM\..\Run: [ATIPTA] atiptaxx.exe
O4 - HKLM\..\Run: [MultiRes] C:\Program Files\MultiRes\MultiRes.exe
O4 - Global Startup: In2Cable Login.lnk = C:\Program Files\In2Cable\CMAAClient.exe
And Event Viewer says :
The shell stopped unexpectedly and Explorer.exe was restarted.
For more information, see Help and Support Center at
http://go.microsoft.com/fwlink/events.asp.
