Old 23-10-2006, 05:41 PM   #1 (permalink)
Pragadheesh's Avatar
Unhappy colour of task bar...
is it possible to change d color or task bar (from blue to black or any other colour) and also d colour of start menu??? how to do it frenz...plz help...
Pragadheesh is offline
Old 23-10-2006, 10:18 PM   #2 (permalink)
Default Re: colour of task bar...
I hope you are asking for a theme. If yes... look here: http://www.deviantart.com/deviation/8841742/
downlaod here or here
RajŪ Anyone else is not me...!!!
rajas is offline
Old 23-10-2006, 10:37 PM   #3 (permalink)
sree_shan's Avatar
@pragadeesh
Changing the look of Taskbar & Start Menu Properties box:
Open %windir%\Explorer.exe file, and goto: Dialog -> 6 to 1135 -> 1033.
u can use resource hacker and edit the above file....
u can also refer to the following posts to get the tutorials on resource hacker :
TUTORIAL: All About Resource Hacker! A Brief Tutorial
TUTORIAL: List of Files to be hacked using Resource Hacker!
resource hacker
http://www.thinkdigit.com/forum/sear...searchid=76184
=>@ sree_shan @<=
"I do not fear computers. I fear the lack of them..."
sree_shan is offline
Old 27-10-2006, 09:58 PM   #4 (permalink)
Post Re: colour of task bar...
thanx a lot SreeShan... i tried to change d Shut down dialog box
i opened "%windir%\System32\MSgina.dll" in Resource Hacker then,
Dialog -> 20100 -> 1033
i did some changes and compiled d script it,
but after compiling it how to save d .dll file...should i save in the same name i.e MSgina.dll ???
but when i tried to save in the same name, it's displaying an error saying
"Cannot create file C:\WINDOWS\system32\msgina.dll"
wat to do??? plz help me in sorting out this problem...
Old 27-10-2006, 11:02 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Its happening bcoz of WFP (Windows File Protection) service
Either disable the WFP service using a patcher or just save the file in other location or with a different name and then boot into any other OS or in DOS and then replace the original file with ur hacked one
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 28-10-2006, 04:54 PM   #6 (permalink)
thanx a lot vishal... but how 2 find "SFCDisable" in the registry..??where 'll it be??!!'m very new to this registry n stuffs.. plz help me... also how to change its value to "ffffff9d" to disable WFS????
Old 28-10-2006, 11:30 PM   #7 (permalink)
Wise Old Crow
blueshift's Avatar
Goto this key:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
Change the value of SFCDisable to 1.
or you go through this VishalGupta's thread below for using softwares to disable WFP service (without using Regedit)
List of Some Useful System Utilities!
blueshift is offline
- by Krow
