No Doubt, Resource Hacker is one of the most powerful tool ever to have build
that enables us to modify the resources of (exe, dll, ocx, cpl, scr) files.
There are thousands of people who download & use it!!!
But thers are few limitation; Cannot Read compressed files (Compressed with EXE compressor),
its avalable as a zip file (Difficult to carry & use) & the most fructrating thing
I feel is browsing for the file to Hack (Open With Resource Hacker).
I am Not a Geek so I cant manipulate the Compressed EXE thing,
But I have created a installation Setup that would actually install the Resource Hacker in your system & Added a 'Hack Resources' option to (exe, dll, ocx, cpl, scr) files context menu.
And The Icon of Course, I changed It.
Want A Copy to check,
Click the link &...
http://s5.yousendit.com/d.aspx?id=2B...I16RN53EIZML7K
& please Don't Delete the File From the Server !
NOTE: The link will work till 30-12-2004.
I am Not a lawyer & I don't know if I can Distribute. So use it for 15 days & then UnInstall it.
(This effort is only to Apprisate the task undertaken by the developers of Resource Hacker)
