Old 23-10-2006, 01:34 PM   #1 (permalink)
Default DVD Writer is not working
Hi,
I have LG DVD Writer. From last one month I cant write any deta DVD with. IT start writeing deta on it and give error after 6% done. this is with every DVD.
Why? What is going wrong? I am using Nero for burning. and cant write 600mb also. while I have 1.5 gb free space on C:
Please help me
neelg22 is offline
Old 23-10-2006, 01:51 PM   #2 (permalink)
Arrow Re: DVD Writer is not working
i think you need to free out more space
and then first try to burn an image disc with nero and then to on a disc so that you can know if it is a system problem or the fault lies in the DVD writer
sahaymr is offline
Old 23-10-2006, 04:45 PM   #3 (permalink)
Pragadheesh's Avatar
Post Re: DVD Writer is not working
i think its d problem wid ur LG writer. better get it serviced..
Pragadheesh is offline
Old 31-10-2006, 03:16 PM   #4 (permalink)
Default Re: DVD Writer is not working
Thanks. I think I should go for service centre of LG.
neelg22 is offline
Old 31-10-2006, 05:40 PM   #5 (permalink)
LG and Samsung...are the worst manufacturer of CD/DVD drives!!
jack// ani is offline
Old 31-10-2006, 05:45 PM   #6 (permalink)
I am also getting a problem with LG DVD writer. I have received a problem is it only writes DVD not CD. I am awaiting to repair problem for 2 months. So I have changed that one to new one. Because, electronic items lifes are not too long depending how we use.
essarrenn is offline
Old 31-10-2006, 10:31 PM   #7 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Any CD/DVD Burning Program requires a similar amount of space in C:/ or in whatever partition they are installed for burning the data
For example,when you want to write a DVD,the CD/DVD Burning Program requires space of about 4.5 GB on the C:/ as Temporary Cache
If it doesnt get this,there might be errors in writing a CD/DVD
The second option is to check the CD/DVD writer for any errors
techtronic is offline
Old 01-11-2006, 11:11 PM   #8 (permalink)
NikhilVerma's Avatar
What error does it give ?
Power Calibration ?
NikhilVerma is offline
- by Krow
