i have many shortcut icons on my desktop, double clicking on them 2 open any application is 2 painful ..... so i tried assigning shorcutkeys in its properties bt it isnt working ...
whot 2 do ?
man you you may make a folder where all the shortcuts are to be copied.
Then you goto the properties of the shortcut files.. There you may find putting shortkeys and put a unique shortcut key in all.
