Old 22-10-2006, 01:35 AM   #1 (permalink)
Exclamation can't burn more on CD and DVD
hi all i have got sony DVD RW DRU 820A
my problem is that i am not able to burn cd of 800 mb and dvd of 4.7 gb
as nero 7.2 only recognize 700 mb of cd and 4.3 gb on dvd
how can i use the full space on the disk?
sahaymr is offline
Old 22-10-2006, 07:41 PM   #2 (permalink)
dinesh_mettur's Avatar
Default Re: can't burn more on CD and DVD
no it will work or download the nero 7.5 reloaded pack and try it in new version some of the bugs are fixed
___________________________
~~ THINK DIFFERENT ~~
.. U'r Ultimate Place To Enjoy ..
www.funisland.co.nr
dinesh_mettur is offline
Old 22-10-2006, 11:25 PM   #3 (permalink)
nishant_nms's Avatar
did u selected Burn DATA CD. If so the try to select Burn Data DVD
nishant_nms is offline
Old 23-10-2006, 09:17 AM   #4 (permalink)
Unhappy Re: can't burn more on CD and DVD
for DVD i have also extended the over burn but it is limited to maximum of 100 mb
i think i need to go in for nero 7.5
sahaymr is offline
Old 23-10-2006, 05:17 PM   #5 (permalink)
Pragadheesh's Avatar
Post Re: can't burn more on CD and DVD
u cant write more than 4.3 GB on a DVD... coz,
in manufacturing standards of hardisk 1 GB = 1000 MB.
So, when multiplied 4.3 GB * 1024 * 1024 * 1024 = 4617089843.2 bytes or 4.7*10^9 bytes (approx).
OK now divide (4.7 *10^9)/1024*1024*1024 = 4.3..
So you get 4.3 GB on the DVD or 4.7 GB of data as said my manufactures.
Refer to http://www.thinkdigit.com/forum/show...282#post320282
But donno wats d prob wid cd...
Pragadheesh is offline
Old 30-10-2006, 07:04 PM   #6 (permalink)
yeah i take ur point and agree on it but there are two different varients of the blank disc 700mb and 800mb one then how will you use that 800mb cd they are being differeniated by the vendors
sahaymr is offline
Old 30-10-2006, 07:11 PM   #7 (permalink)
Livin' in the ghetto
AshishSharma's Avatar
The 800 Mb Cd's which I've used usually have 100 MB Overburn so if you enable Disk Overburn though it'll show 700 MB but you should be able to burn 800 MB.
~.~ Never argue with idiots, they just drag you down to their level then beat you with experience. ~.~
AshishSharma is offline
Old 30-10-2006, 10:32 PM   #8 (permalink)
royal's Avatar
Red face Re: can't burn more on CD and DVD
I have read in certain forums that dvd overburning is possible upto 4.5 GB (mostly with Verbatim brand DVD+R) but I have been unable to do so with MoserBaer DVD-R . I asked if anyone in this forum knows the procedure but it seems no member has any actual experience of overburning DVDs
royal is offline
Old 31-10-2006, 06:27 PM   #9 (permalink)
Well you can use something like DVD Shrink to bring down the size of DVD to 4.3 GB and then burn it to DVD.
It's a freeware available here: http://www.dvdshrink.org/what.html
Do lemme know if this helps
Old 31-10-2006, 06:47 PM   #10 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Umm.. If im not wrong, overburning is only possible with DVD+R
kalpik is offline
Old 31-10-2006, 09:06 PM   #11 (permalink)
^^^ True but if we can't increase the space maybe we can compress the data ? Has nyone done tried using something like DVD Shrink and then burn the DVD? I can't test it bcz I don't have a DVD Writer but it does shrinks the DVD thats confirmed ..
Old 31-10-2006, 10:23 PM   #12 (permalink)
royal's Avatar
Cool Re: can't burn more on CD and DVD
so that's it can u suggest any reliable brand of DVD+R ?
royal is offline
Old 01-11-2006, 07:30 AM   #13 (permalink)
kalpik's Avatar
Hmm.. Verbatim is obviously a *very* good brand, but you can also try MoserBaer. Do tell us how it goes! (I've never tried overburning a DVD )
kalpik is offline
Old 01-11-2006, 12:44 PM   #14 (permalink)
royal's Avatar
Question Re: can't burn more on CD and DVD
Is MoserBaer DVD+R available commonly
royal is offline
Old 01-11-2006, 02:40 PM   #15 (permalink)
kalpik's Avatar
Yeah! Its available in Nehru Place commonly.. Dunno about your place! Anyway, a DVD+R is better than DVD-R.
kalpik is offline
Old 01-11-2006, 05:23 PM   #16 (permalink)
^^^Whats the price of DVD+R in Nehru Place ?
Old 01-11-2006, 07:38 PM   #17 (permalink)
kalpik's Avatar
Actually i never inquired about the price, but there should not be much diff. DVD+R is a only a little more expensive than DVD-R.
kalpik is offline
Old 02-11-2006, 01:34 PM   #18 (permalink)
^^^ Nopes DVD+R is about double the price of DVD-R here in B'lore. I'll be in Delhi next week so might buy it from NP if it's ny cheaper.
Old 02-11-2006, 10:40 PM   #19 (permalink)
royal's Avatar
Talking Re: can't burn more on CD and DVD
exactly how is it better and why dont you go for it yourself
royal is offline
Old 03-11-2006, 08:16 AM   #20 (permalink)
kalpik's Avatar
http://www.cdfreaks.com/article/113
I never went for it cuz generally i buy disks from near my place only (Not nehru place) and my local guy does not have DVD+R. Anyway, the price difference also matters cuz i burn in bulk! Anyway, i dont think there may be too much a difference between the price of a DVD-R and DVD+R.
kalpik is offline
- by Krow
