Old 23-12-2004, 01:42 PM   #1 (permalink)
Default P2P Connection Problem
Hi Folks,
There is some problem in connecting to Kazaa and Shareaza.It display Connecting and even after 5-10 mins nothing happens.
I am using dialup BSNL Jalandhar.
Any suggestions.
At First the problem is with kazaa only but now both.
Lovedeep Wadhwa
cheetah is offline
Old 23-12-2004, 10:13 PM   #2 (permalink)
i read ur other thread abt "unofficial guide to ethical hackin"
i read ur alst post
first of all dont scream ( caps is considered screamin )
be nice as far as u can no matter what
and ok since ur a newbie to everything .. fine
let go of it once
but not everytime
as a newbie it IS ur responsibilty to check the forums rules
and forum rules state that u must search before creating a new topic
so as nicely as i can put it .. i ask u to search
look for "http tunnel" or "hopster"
u should get a list of threads
read alib_i's post in any of them ... ull get ur answer
cheers
No Mercy, No Limits.
theraven is offline
Old 24-12-2004, 12:20 PM   #3 (permalink)
mostly becos ur dialup connection is too slow...happens often. Also check with ur ISP if he has blocked the Kazaa and other P2P clients. Try this P2P
www.winmx.com
its a small freeware and its p2p. So try with that.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 24-12-2004, 03:21 PM   #4 (permalink)
Ethan_Hunt's Avatar
Your Isp Seems To Be Enforcing a Firewall For Ur Net Connection......Hence Kazaa Sometimes may or may not connect......Using Http Tunnel Or others May not be of that much use to u as i have tried em myself and the Ports Cannot be opened to much extent Which Kazaa requires .....U can try Out The Latest BitTorrent P2P TEchnology.......It has quite a few Advantages over these traditional P2P's.....Search The forum And Will Get Loads of thread on it and Kazaa As well (Including my own Post that i posted sometime back)
Ethan_Hunt is offline
- by Krow
