a friend of mine is planning to upgrade his computer ...... he will be keeping the moniter, mouse and keyboard ....... he is only willing to spend 12k on the upgrade ..... what config will he be able to get at that price ..................
Strength of A MaN was Once mEasUred with his
BrAiN & bRawN ............ NoW its MeAsureD with hiS RAM & ROM !!!!
This is slightly over your friend's budget, but it will be worth it if he can manage it. He'll be able to play most games on it. If he must, he can keep within 12k by omittimg the floppy drive, use 128MB RAM instead of 256MB, 40GB HDD instead of 80GB.
hey justo...
pimpom suggested u a very good competitive config...
but if u ommit 128MB,it will slow down things a bit...but that too depends on the aplication or use of the PC....try not to ommit RAM,instead go for 40GB HDD...nd if u can get ur old cabinet u save 1000 more!
Hey dude i also saw this kind if config on techtree is this sempron a 64bit proccy y is it so cheap.
No, Semprons are not 64-bit. They're cut-down versions of Athlon XPs, just as Durons were, and also as Celerons are cut-down versions of Pentium 2/3/4. The main difference of these budget CPUs from their big brothers is that they have smaller internal cache memory and in some cases lower FSB.
