Old 21-10-2006, 06:22 AM   #1 (permalink)
hailgautam's Avatar
Cool Mac OS on PC
Since apple has released its Apple Mac PowerBook on an Intel Core2Duo Processor, i wanted to know whether Mac OS X v10.4.x Tiger will work on any PC running on the Intel processors or atleast Intel Core2Duo processor based PCs.
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 21-10-2006, 02:31 PM   #2 (permalink)
AFK
thewisecrab's Avatar
Default Re: Mac OS on PC
If i have not mistaken i think Apple sells its own hardware incorporated with Mac so it cannot b used with PCs (ie systems with Windows).....so i think 2 use a Mac u may have 2 buy another comp designed by Apple 4 Mac
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Old 21-10-2006, 02:35 PM   #3 (permalink)
samrulez's Avatar
Nope, MAC sometimes work on PCs....but the sources through which you have to acquire them is tricky
I think it should run, but the performance may vary!
Sam :D Rulez :lol:
samrulez is offline
Old 21-10-2006, 04:18 PM   #4 (permalink)
hailgautam's Avatar
I was reading a review of Mac PowerBook here:
http://www.laptoplogic.com/reviews/d...e9e70dfb1b481f
According to the review PowerBook nativly supports Winodws XP and Linux. But with the help of Boot Camp.
What is this bootcam neway??
Where you going?
With Luck forward.
- by Krow
