Old 20-10-2006, 02:56 PM   #1 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
Default Change File size!
many times it so happens that wen we d/l something if the d/l breaks in between the file(wen right click->prop)shows the full size rather than actual(d/l is incomplete).so my questuon is why this happens???
2ndly is the reverse posible,meaning can a full file be made to LOOK smaller through some hex editing(5mb to 500kb)??(retaining the remaining part of the file intact)
Without sorrows happiness would be boring!
romeo_8693 is offline
Old 20-10-2006, 03:11 PM   #2 (permalink)
Come get Some
DukeNukem's Avatar
Wink Re: Change File size!
Yes Bro. Windows need to make sure that there is enough space available for the file need to be copied so it reserve that much space. (only when it knows the size of file in advance).
This case is different when you zip/rar file from network.
DukeNukem is offline
Old 21-10-2006, 10:09 AM   #3 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
Default Re: Change File size!
what about 2nd question?
Old 24-10-2006, 03:47 PM   #4 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
is it possible or not possible????any1 plz ans!!!!
Old 24-10-2006, 05:17 PM   #5 (permalink)
blademast3r's Avatar
I guess its not possible, otherwise ppl wud not really care bout file space wud they?
blademast3r is offline
Old 24-10-2006, 05:22 PM   #6 (permalink)
:-o
aakash_mishra's Avatar
@romeo_8693
As far as I know it is not possible
www.amiable.in
aakash_mishra is offline
Old 24-10-2006, 05:25 PM   #7 (permalink)
Livin' in the ghetto
AshishSharma's Avatar
Nyone has idea how explorer calculates the size of files ?
~.~ Never argue with idiots, they just drag you down to their level then beat you with experience. ~.~
AshishSharma is offline
Old 01-11-2006, 04:48 PM   #8 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
ashish got a point.....may be if you cud play around with the way explorer calc's the file size....
@blade....the file will occupy the same space as b4..but it will only show as a smaller file...
Old 01-11-2006, 04:57 PM   #9 (permalink)
Come get Some
DukeNukem's Avatar
as long as the file u are talking about is a MPG, AVi, WMV one
or any video
then use the appropriate cutter to trim the file till it is working
it is a OK tested and duke approved method
for else i havent try and for binary (.exe,.......) files, its not possible (as little as i know)
Computers are like Air Conditoners, thet stop working properly when u open WINDOWS.
Old 02-11-2006, 02:49 PM   #10 (permalink)
^^^ He's not trying to bring down the size but fool Computer into showing incorrect size ...
Lemme add an observation to this ... when you start downloading a torrent file it creates a file folder structure and blocks space for the files downloaded. Now if you look at the properties of the folder it'll show the size which it should achieve on download completion. At this point there is nothing in folder no data but it still occupies huge space ... How does it fools the computer into believing that the data is there ....
I've seen some 2 MB .Rar files for complete Vista CD's which take some 2.5 GB on extraction but contain nothing .... I guess those are blank torrent folder structure compressed with Winrar ....
I might be completely incorrect here ..... can nyone please shed some light on this ..... ?
Old 02-11-2006, 03:19 PM   #11 (permalink)
piyush gupta's Avatar
i think vishal should have answer to these questions waiting for his response
piyush gupta is offline
Old 04-11-2006, 12:29 PM   #12 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
hey ashish u got my point man!!!!
- by Krow
