Old 20-10-2006, 06:28 AM   #1 (permalink)
Default shutdown automatically when power failures
is there any UPS or any s/w for shutting down the computer automatically when the main power failures?
Raaza is offline
Old 20-10-2006, 07:37 AM   #2 (permalink)
Default Re: shutdown automatically when power failures
I think APC UPS comes with a software that can be installed for shutting down the system... But I am not sure...
Arun
sakumar79 is offline
Old 20-10-2006, 08:32 AM   #3 (permalink)
El mooooo
eddie's Avatar
Numeirc UPS comes with this kind of software as well
eddie is offline
Old 20-10-2006, 12:37 PM   #4 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
i think i ball ups do the work
Blogging @ http://classictutorials.com
the.kaushik is offline
Old 20-10-2006, 04:51 PM   #5 (permalink)
hailgautam's Avatar
Many UPSs do the job, but i suggest to go with APC as they are more reliable. mostly they are high end UPS, you have to go to your dealer and ask him, I am not sure that these facilities are available on 500VA UPS . These UPSs have Parallel Port/ Serial Port Connection to the PC, and when the power connection is gone they switch off the system.
hailgautam is offline
Old 20-10-2006, 06:33 PM   #6 (permalink)
what do you mean by High end UPS ?
is it related to price or backup time.
could you please mention it's price too.
thnx 4 all
Raaza is offline
Old 20-10-2006, 08:54 PM   #7 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
there are some UPS that come with a data cable , these UPS have this facility.
Donno specific names.
n00b forever...
~Phenom~ is offline
Old 20-10-2006, 09:06 PM   #8 (permalink)
JGuru's Avatar
Well known UPS brands like APC, Numeric come with a software CD, install the software
also connect your UPS with the cable provided to your PC. Yes, you can also configure
the software to shutdown the PC in case of a power failure.
* Imagination is more important than knowledge.
-Albert Einstein
JGuru is offline
Old 21-10-2006, 10:53 PM   #9 (permalink)
thnx for the helping replies.
I'll contact nearest dealer to get one.
Raaza is offline
Old 22-10-2006, 05:17 AM   #10 (permalink)
hmmmmmmmmmmmmm's Avatar
yes im usin...APC it shutdown wen ever battery is low
hmmmmmmmmmmmmm is offline
- by Krow
