Re: Properties of File
select file Alt+Enter is the best way to find file size and other properties.
If u meant properties of video/audio files, like bit rate... go for KLite Codec pack which includes some sw doing the same. For audio, if u install dmc converter, "alt+Enter" on audio file also give bit-rate, file length in min... in the detailed summary
