Old 23-12-2004, 06:25 AM   #1 (permalink)
Default plz reccmmend a fax machine
hi ppl....plz recommend me a good fax machine 4 my office....
budget is around 5-6k....maybe a bit more but should b a good one
thnx
AMD Athlon 64-2800@ 2.4 Ghz,Asus K8N,2X1GB DDR400 Transcend Memory @2.5-3-3-5,Segate 160GB PATA,LG GSA-H10N,BBA X800 XT PE,Windows XP+SP2,Vista Ultimate,Ubuntu 6.10,Altec Lansing ATP3,Philips SHP805
sagar_mutha is offline
Old 23-12-2004, 11:57 AM   #2 (permalink)
tuxfan's Avatar
I use a brother plain paper fax machine. It is good. I am so far satisfied. I got good reviews about it from the persons who use it. So I bought it. Since it is a plain paper fax, it is a bit expensive - about 8300. Brother fax machines are imported and distributed in India by Godrej. So the warranty support is from Godrej. Per paper cost comes to about Rs. 1.50/-
BTW, there is a MFD (Muli-Function Device) from HP that could also serve your purpose. Its a printer, scanner, fax, telephone, modem, etc. all rolled into one. For about the same price, you get a scanner too, although it is not a flat bed scanner, so you can't scan from books/mags.
tuxfan is offline
Old 24-12-2004, 06:14 AM   #3 (permalink)
thanks dude,is there any website where i can view the price comparisons of fax machines
Old 24-12-2004, 11:22 AM   #4 (permalink)
tuxfan's Avatar
Sorry, I don't know of any. You will have to google it out on your own. But nothing works better than an actual personal market study. Do it online. Empower yourself with some more knowledge and then go offline for the final study
tuxfan is offline
- by Krow
