Old 19-10-2006, 08:12 PM   #1 (permalink)
prashantban's Avatar
Default how to block a website
Friends my brother always sits in orkut for more than 3 hrs and i want to block it.
pls tell me something about it to block it
something new other than those of internet options
prashantban is offline
Old 19-10-2006, 08:32 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: how to block a website
goto internet options>security and put it in d list of restricted sites
Pathik is offline
Old 19-10-2006, 08:34 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
go to C:\WINDOWS\system32\drivers\etc
open host file. add the following entry to it
127.0.0.1 www.orkut.com
save it. replace the old one with this new one.
use host manager utility from http://www.aldostools.com/hosts.html to achieve this; its easier.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 20-10-2006, 02:13 AM   #4 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Cool Re: how to block a website
The fool proof way is to enable Content Advisor using IE
Its located under IE -> Internet Options -> Content -> Content Advisor
Just enable it and it will prompt you for a password to allow or deny a site to be visited
techtronic is offline
Old 20-10-2006, 02:55 AM   #5 (permalink)
String Phreak
mediator's Avatar
^^ What if the brother downloads Firefox,opera etc??
Neways I second @anandk's method, there is also firewall method.
mediator is offline
Old 20-10-2006, 10:32 AM   #6 (permalink)
Great Work The Digitians Thankyou
Old 20-10-2006, 11:48 PM   #7 (permalink)
techtronic's Avatar
In that case Enable Software Restriction Policy in XP
Old 21-10-2006, 10:56 AM   #8 (permalink)
kl_ravi's Avatar
Sooner or later, your brother might smell something fishy. So try Cybersitter.
Cybersitter blocks websites silently and shows up a blank page so that the user might think that the site is down.
Other sites continue to work as normal.
Everything that follows is a result of what you see here...!!!
kl_ravi is offline
Old 21-10-2006, 12:16 PM   #9 (permalink)
JGuru's Avatar
You can use CyberPatrol (http://www.cyberpatrol.com/), NetNanny (http://www.netnanny.com/).
Using these Parental control softwares you can monitor the browsing patterns of
users, block porn, limit the time spent online, block websites & so on.
* Imagination is more important than knowledge.
-Albert Einstein
JGuru is offline
- by Krow
