Old 04-08-2004, 07:34 PM   #1 (permalink)
alib_i's Avatar
Default cd not recognizing data ..
i just burned a cd in multi session mode on a frd's comp ..
it already had a folder burned .. it was its 2nd session ..
but now my cd-drive is not recognizing the data which i burned later ..
it simply shows one 121mb folder but the cd has total 600 mb data ..
the whole data is visible on his comp and even on other ( including hcl ) comps ..
i have a 6months old lg 52x drive ... and cd was quite new too ( no scratches )
now .. does being in slave mode anything to do with it ..
i have also stopped the cd burning service of winxp ( simply cos i dont have a cdrw ) ..
help me out plzzz
-Metallica
alib_i is offline
Old 04-08-2004, 07:43 PM   #2 (permalink)
alib_i
Download the aspi drivers and install them. Restart, and see if you can read the cd now.
http://www.adaptec.com/worldwide/support/driverdetail.html?sess=no&cat=/Product/ASPI-4.70&filekey=aspi_471a2.exe
sailendra is offline
Old 04-08-2004, 09:55 PM   #3 (permalink)
The Photoshop Guy
cooljeba's Avatar
it has happened with me too. Usually i dump that CD .
BTW try Ultra ISO that may help u a bit .
..:: peace ::..
Jeba
cooljeba is offline
Old 05-08-2004, 02:47 PM   #4 (permalink)
alib_i's Avatar
shailendra ...
i tried installing aspi driver .. but it didnt help ...
and cooljeba .. ultaISO is one the best soft iso making software ..
but its not helping me out
the TOC is somehow corrupted ..
i installed BadCopy pro and ISOBuster ...
but no progress
-Metallica
alib_i is offline
Old 05-08-2004, 03:24 PM   #5 (permalink)
its happened with me too sometimes...
but i think the problem may be that... you burned the first part of the cd at a diff speed than the second part... i have seen this happen..
you should burn the multisession cd at one single speed... and i think the slower the better.. though can`t say anything..
its my gift....
its my curse....
who am i??
i`m spiderman....2!
godzi_85 is offline
Old 05-08-2004, 04:16 PM   #6 (permalink)
da' Ťurntable ruleth
techno_funky's Avatar
yup thts wht always write the cd at a specific speed
especially multi session cd's
burn em at a specific speed
if not possible then atleast at a lower speed
cause high speed burned disc always creates a reading problem
and also there are possiblilties of more error at high speed
| Dell Studio 15 | iPod Touch 16GB (Stolen) | iPod Video 5.5G 30GB | Sony Ericsson W910i |
| Sennheiser PX 100 | Sennheiser HD 202 |Creative EP630 | Altec Lansing ATP 3 |
techno_funky is offline
Old 05-08-2004, 05:05 PM   #7 (permalink)
Originally Posted by alib_i
shailendra ...
but no progress
No use installing aspi drivers here. Did u finalise the disk, It so happens that if some older roms and some newer ones too fail to recognice multi session disks.
www.techenclave.com Ecumenical Technology !:)
blade_runner is offline
Old 05-08-2004, 06:41 PM   #8 (permalink)
its not abt the roms
i face the same problem
its really messed up !!
i think its abt continuin the multisession disc from a specific track or something
well anyways since i dunno much abt that im gonna shut up
try this ... if u have a second rom try it in that
or get 2 drives somehow
its crazy but it works for me ..
one track is accessed by one drive ... the other by the other ..!! no jokes !!
No Mercy, No Limits.
theraven is offline
Old 05-08-2004, 06:58 PM   #9 (permalink)
JAK
What the Heck !
JAK's Avatar
Default Re: cd not recognizing data ..
help me out plzzz
Hmmm...
As of now u can use Nero multimounter to access all data....
9x/Me
ftp://ftp9.nero.com/attach/Multimounter_9x.zip
2k/XP
ftp://ftp9.nero.com/attach/Multimounter_2k_xp.zip
Update ur firmware....
Risk more than what others think is safe.
Care more than what others think is caring.
Think more than what others think is thoughtful.
Do more than what others think is possible.
JAK is offline
Old 05-08-2004, 07:11 PM   #10 (permalink)
JAK
What the Heck !
JAK's Avatar
What u think is incorrect m8...
There is no speed binding in any burnin format...
The only care u need to take while burning a muti session CD is that u should select
"Continue Multisession" instead of "new multisession" in NERO
else u'll end up with out any previous sessions as they will be excluded from the TOC
However these can still be accessed using software like ISO buster or our godd Old NERO burnin....
@ alib_i
Hey dude u cud also use ISO buster to read data off the disk..Try it..
JAK is offline
Old 08-08-2004, 10:40 PM   #11 (permalink)
alib_i's Avatar
Originally Posted by JAK
Hey dude u cud also use ISO buster to read data off the disk..Try it.. Wink
scroll up dude and read my reply ..
nero multimounter requires nero to be installed isnt it ...
and i dont have a writer and henco dont have nero installed ..
and yes i specifically remember that i burned them at different speeds .. so i suppose that shud be the problem ..
as for now .. ive dumped it .. cos there seems no possible solution
-Metallica
alib_i is offline
Old 17-08-2004, 09:08 PM   #12 (permalink)
Default A solution at last!!!
Hello chaps!!!
I wuz redirected to this post from my own post elsewhere.
Here is a third party Solution for this whole mess.
Get a shareware proggie called CD&DVD Analyze. You can get it here:
http://www.download.com/3001-2140-10295850.html
This fellow does the job neatly. It can read all ur sessions on CD's burnt at different speeds, using a CD ROM / CD-RW Drive. Only restriction being that u can't directly acess the files. To acess files individually u gotta save the file to a location on the Hard disk & then acess it. There is a floppy icon in the program interface window which is used to save the selected files to a location of ur choice.
If anyone wants any further assistance with the proggies usage feel free to mail me at: hotjim99@yahoo.com ...(It has a 30 usage limitation)
Cheers
melloowmel is offline
- by Krow
