Old 22-12-2004, 05:33 PM   #1 (permalink)
adit_sen's Avatar
Default IM GOING MAD
hey guys, i really need your help on this one.
wheneva i start certain programs, such as powerpoint or my getright download manager, i get
a blue screen error which says
'A problem has been detected and windows has been shut down to prevent damage to your
computer. The file object passed to IOCancelFileOpen is invalid. It should have a reference
of 1. The driver that called IOCancelFileOpen is at fault'.
Then i get a msg about going to safe mode and removing any new installed hardware and all.
The last msg is
TECHNICAL INFORMATION
STOP **0x000000CB (0x812A7E08, 0x00000000, 0x00000000)
Beginning dump of physical memory
Physical Memory Dump Complete'
This error comes only for certain programs, such as the ones i have mentioned earlier. I
have tried scanning for virus and also ran spybot, but they both didnt come up with
anything. i've even tried system restore, but no luck. reinstalling windows or the
mentioned programs also dont help.
the error log in administrative tools says
'The System Restore filter encountered the unexpected error '0xC0000001' while processing
the file '' on the volume 'HarddiskVolume1'. It has stopped monitoring the volume.'
im at my wits end cuz i have a project to submit by next week (im still in skl), and i
need to use powerpoint and the net....SO....H E L P
btw im running a P4 2.4, 256MB, Winxp service pack 2.
thankx
adi
AMD 4400+ X2; Compaq Presario M2202TU; Dell Inspirion 500m; Windows Vista Ultimate
adit_sen is offline
Old 22-12-2004, 09:15 PM   #2 (permalink)
Might be a virus!
Due to a startup program called mskd32.exe
Googling found me this
This might help you!
Whatever happens, happens for good!
ramank is offline
Old 22-12-2004, 11:21 PM   #3 (permalink)
sting's Avatar
try this one also http://xpressionsz.com/phpBB2/viewtopic.php?t=495
Visit my Daily Photo Blog at http://www.iamsarath.com
sting is offline
Old 23-12-2004, 10:24 AM   #4 (permalink)
Your hard disk seens to have physical error . make a boot win 98 floppy and scan the hard disk with scandisk surface scan.
ironcross77 is offline
Old 23-12-2004, 03:33 PM   #5 (permalink)
adit_sen's Avatar
hey guyz...
thankx a lot for ur help. i just figured out the problem. it wuz wit avg antivirus. i had recently installed avg antivirus ver 7.0 a few days back. so the moment i uninstalled it, things came back to normal. so its goodbye to avg from me......guess i better switch to some other antivirus solution.....maybe avast or something...
thanx neways...
peace
adit_sen is offline
Old 24-12-2004, 02:31 AM   #6 (permalink)
Ashis's Avatar
Originally Posted by adit_sen
hey guyz...
thanx neways...
peace
Congr....... Problemo Solved
Try ZoneAlarm Security Suit
Got Any tricky problem with Trying ZoneAlarm Security Suit
Then PM Me
Ashis is offline
- by Krow
