Old 17-10-2006, 07:14 PM   #1 (permalink)
Thumbs down Help on ME
Hi
I had been using WINDOWS ME for a long time.
My C: has a size of 2.5 GB space. Unfortunately when I check the properties of my Program Files and Windows, I found that only 1.5 GB is used. But there is a folder which is hidden named '_Restore' which took my 1 GB of C:. Also I cannot delete it in Normal Mode.
Is it neccessary to run Windows or any other Programs. It also contain another folder 'TEMP' which has almost 10000 files which has extension '.cpy'. What could I do.?
Please give me an effective advice.
Jinsu M Jais
jinsujais is offline
Old 17-10-2006, 07:46 PM   #2 (permalink)
Default Re: Help on ME
_Restore is the system restore folder which stores important information about system condition to help recover in case of registry corruption etc. If you prefer to turn off system restore, you can do it through Right-click on My Computer-> Properties->System Restore...
Arun
sakumar79 is offline
Old 17-10-2006, 08:11 PM   #3 (permalink)
aku
Gonna make it BiG
aku's Avatar
Location: Familiar with Java... SORRY POINTER NOT ALLOWED!!!
inside the temp folder.. 'Ctrl+A'--'Shift=Del'... that'll do it
aku is offline
