Old 17-10-2006, 02:39 AM   #1 (permalink)
clmlbx's Avatar
Smile Digital Dolby 5.1 ?????
Hi friends
I want my songs and movies to be converted in 5.1 surround sound while
burning
So how can i do that
I am using nero 7.5.1.1 premium .
Does this version of nero include this feature .
If so how how do i use it .
clmlbx is offline
Old 17-10-2006, 11:25 AM   #2 (permalink)
Wink Re: Digital Dolby 5.1 ?????
Try this
http://www.tomdownload.com/dvd_softw...vd_creator.htm
But u know, I had written a MP3 DVD using Latest Nero(total 900songs in a DVD 5) and played in VINVERTH 5.1 DVD player. It plays 5.1 CHannel sound. I dont know how. But it is true. I dint tried other players.
ranjithbajpe is offline
Old 20-10-2006, 12:02 AM   #3 (permalink)
clmlbx's Avatar
Default Re: Digital Dolby 5.1 ?????
hey pls someone answer
ok
if not in nero then make it in roxio easy media creator 9
clmlbx is offline
Old 20-10-2006, 07:23 AM   #4 (permalink)
nil_3's Avatar
[QUOTE=clmlbx]I want my songs and movies to be converted in 5.1 surround sound while burning, how can i do that?[QUOTE]
Songs:
The songs that are currently available in the market are all in .WAV or .MP3 format which has strictly two channel audio. You cannot convert it to 5.1 channel. However, some recording companies are currently releasing 5.1 channel music CDs. If you get them, then you can burn it with Nero.
Movies: 5.1 channel movie DVDs can be burned with Nero and then you will get 5.1 channel audio experience.
P4 3.0GHz Dual-core.
Intel 945GNT MoBo.
1GB RAM.
Seagate 160GB SATA HDD.
HP 16X Dual Layer DVD Writer.
Coloursit 450Watt SMPS with NAVTECH cabinet.
Samsung SyncMaster 740N TFT LCD 17" monitor.
nil_3 is offline
Old 20-10-2006, 10:05 AM   #5 (permalink)
:-o
aakash_mishra's Avatar
I think nil_3 is right you can't convert 2 channel audio to 5.1 channel audio
www.amiable.in
aakash_mishra is offline
Old 20-10-2006, 11:41 AM   #6 (permalink)
Hey I had tried writting ordinary mp3 in to DVD and played in a 5.1 music system. Its working . why cant try it?
I guess it is 5.1 channel sound because SOngs which played is distributed in 5 speaker. I mean when playing, some of the music will played in back speakers. I had listen to song of Krish in theator and the effect there was same as what the dvd gave me in my player.
And when i tried to old songs it wont give that effect. Only for new songs i get.
Old 21-10-2006, 12:11 AM   #7 (permalink)
clmlbx's Avatar
Smile Re: Digital Dolby 5.1 ?????
but i have listen something about plugins that u install then u can get 5.1 sound (nero) .
is ther any solution if not nero ( any app )
clmlbx is offline
Old 21-10-2006, 07:05 PM   #8 (permalink)
jz2linkinpark's Avatar
yeah, even i think so...but whats the use anyway..you can just tweak the options with the player or speakers to put all the speakers to use....no use really, converting two channel to 5.1....
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
