Old 22-12-2004, 02:01 PM   #1 (permalink)
Default ATA/133 on ATA/100 ???
My CPU & Chipset (1.9 GHz,845 GL) supports ATA/100. I plan to buy SAMSUNG 160 GB HDD (non-SATA) which is ATA/133. Will it work if i buy this HDD??? Help Urgently Needed.
Shwetanshu Srivastava
shwetanshu is offline
Old 22-12-2004, 02:30 PM   #2 (permalink)
It will work; but at ATA-100...
My advise, better buy a ATA-100 HDD with bigger Cache of 8Mb as against the normal of 2mb... that will give a performance boost ...
delhibhai1000 is offline
Old 23-12-2004, 11:47 AM   #3 (permalink)
the ATA 133 is backward compatible ....... as ur mobo supports ATA 100 .... the harddisk wid ATA 133 will actually work at ATA 100 thereby giving you a performance lower than its potential
Strength of A MaN was Once mEasUred with his
BrAiN & bRawN ............ NoW its MeAsureD with hiS RAM & ROM !!!!
justo is offline
