Well... What you have done is you have made Google your default search engine and messed some options in Internet Explorer ...
Do this thing .. :
Internet Explorer > Tools > Internet Options ..
Click on Advanced tab ..
Under the Search from the Address bar, Select :
Just go to the most likely site ...
Click on Apply .. OK ..
Now your problem is solved ..?
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
