Old 15-10-2006, 11:31 PM   #1 (permalink)
rup
rup's Avatar
Default problem with folder option
hi...can anybody plz suggest how to find the "folder option" which is found in "view" menu or in "settings"...coz i hv a prob i.e i am unable to find it in my pc having 98SE o/s..............................................:co nfused:
------spread every1 the best u have, certainly u'll hv the best.....
rup is offline
Old 15-10-2006, 11:39 PM   #2 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Default Re: problem with folder option
U can also find it in Control Pannel
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 16-10-2006, 12:22 AM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Some viruses also disable Folder Options!
But u can try this:
Open "regedit" and goto:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Explorer
And in right-side pane, check for NoFolderOptions and if its there, then delete it!
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 16-10-2006, 12:31 AM   #4 (permalink)
virus_killer's Avatar
google for the "XPconsole ", dwnld this .exe file and enble ur folder option
__________
here's da link http://www.dougknox.com/xp/utils/xp_securityconsole.htm
Last edited by virus_killer; 16-10-2006 at 12:31 AM. Reason: Automerged Doublepost
virus_killer is offline
Old 17-10-2006, 11:12 PM   #5 (permalink)
rup
rup's Avatar
thax vishal for ur suggestion....but sorry there is no such "NoFolderOption" in the right pane of "......\Explorer"....so, it still not working......
rup is offline
Old 17-10-2006, 11:20 PM   #6 (permalink)
How to hide folder in windows XP without using folder guard This problem might have been discussed
konstAnt is offline
