Old 15-10-2006, 11:08 AM   #1 (permalink)
Default bluy ray discs
hi
any body know how to blueraydisc works
sandurai is offline
Old 15-10-2006, 11:11 AM   #2 (permalink)
Cool Re: bluy ray dics
Blue ray disc is similar to other discs. it has higher storage capabilities(50-110 GB) and uses a blue Laser instead of Red.
The SHARK is offline
Old 15-10-2006, 01:30 PM   #3 (permalink)
gooby pls
Third Eye's Avatar
Default Re: bluy ray dics
Originally Posted by sandurai
hi
This link tell you: http://electronics.howstuffworks.com/blu-ray.htm
Third Eye is offline
Old 15-10-2006, 01:43 PM   #4 (permalink)
dissel's Avatar
Default Re: bluy ray discs
Acording to Digit Mag .... A blu-ray Single layer 25 GB disc cost Rs.960.
dissel is offline
Old 15-10-2006, 01:51 PM   #5 (permalink)
As per Sony India site, the MRP is Rs.1000/-. So the street price should be cheaper. And once the drive becomes common, the price will come down drastically as it happened in the case of CD and DVD.
V.Prem Kumar
janitha is offline
Old 15-10-2006, 01:52 PM   #6 (permalink)
nikhilrao's Avatar
thnku for the info. Is it avelble in india ?
nikhilrao is offline
Old 15-10-2006, 08:16 PM   #7 (permalink)
If you have a BRay writer you can get it or order it at a Sony show room. Otherwise, for what?
V.Prem Kumar
janitha is offline
Old 16-10-2006, 07:45 AM   #8 (permalink)
hmmmmmmmmmmmmm's Avatar
n blue ray DVD writer Costs 45000 /- Only...huh
hmmmmmmmmmmmmm is offline
Old 16-10-2006, 08:03 PM   #9 (permalink)
niks999's Avatar
Wink Re: bluy ray discs
For further information, see the december issue of digit if you have that, or see the pdf of that issue in any cd/dvd!!
It has a deep knowledge and comparison between blue-ray and HDD Disks
nIKHIL pATEL
bHILAI
niks999 is offline
