Old 14-10-2006, 02:31 PM   #1 (permalink)
Manchester United
abhijit_reddevil's Avatar
Question How to convert a DVD image to multiple CD images?
Hi,
I need to convert a DVD image to multiple CD image and write the data to multiple CDs for reading on a machine which has only a CD ROM drive. Is it possible? If yes, how?
Thank you.
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
abhijit_reddevil is offline
Old 14-10-2006, 02:37 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: How to convert a DVD image to multiple CD images?
does the dvd hav data only or its a huge setup..
Pathik is offline
Old 14-10-2006, 07:34 PM   #3 (permalink)
jz2linkinpark's Avatar
i think it can be done with winrar...
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
Old 15-10-2006, 12:41 AM   #4 (permalink)
Manchester United
@pathiks: It's containing multiple data worth over 3.5GB.
@j2linkinpark: How to break the data by winrar?
vbmenu_register("postmenu_323792", true);
Old 15-10-2006, 08:43 AM   #5 (permalink)
nishant_nms's Avatar
compress it using winrar and in split option select 700 MB and u will be able to burn it on CDs. However before using i u will need to uncompress all the cds to use it
nishant_nms is offline
