Hi,
I read a post on using the uxtheme patcher to patch the uxtheme.dll file so that you can install various themes.
I patched this file and copied a theme from the July digit issue (forever blue i think). Although I can see the entry in the theme drop down, I am not able to successfully apply that theme. Only the wallpaper and a few icons get changed, keeping the taskbar, start menu as it is.
1. How do get to change this.
2. What does this patcher actually do? I mean why is it necessary to patch it?
3. difference between Theme and Visual Style.
4. do I need to make changes to the registry.
Thanks in advance...
